cado-nfs - Re: [Cado-nfs-discuss] Correct method for SNFS
  • To: snae@unseen.is
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Correct method for SNFS
  • Date: Mon, 19 Feb 2018 11:57:44 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi,
On Mon, Feb 19, 2018 at 10:41:27AM +0000, snae@unseen.is wrote:
> When I try to run it appears promising but then just stops at the
> Lattice Sieving:
It does not "stop at the Lattice sieving". It actually *does* nothing.
You've just run the python orchestration script. While this script has
the capacity to spawn compute jobs by itself, it only does so if you
specify some "slaves.*" parameters.
Here, you didn't, so that you're expected to do as the script suggests in
order to feed it with sieving data.
> Info:HTTP server: You can start additional cado-nfs-client.py scripts with
> parameters: --server=https://<computer>:34887
> --certsha1=bf01c2becfa2974b39592a187a4e221f7d50a7db
(Note though that if your hostname is really <computer>, then you're
bound to have some trouble).
E.
