cado-nfs - [Cado-nfs-discuss] Program fails immediately after entering merging
  • To: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
  • Subject: [Cado-nfs-discuss] Program fails immediately after entering merging
  • Date: Mon, 26 Feb 2018 18:14:47 +0000
  • Accept-language: zh-CN, en-US
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=wangqianzhou@outlook.com; spf=Pass smtp.mailfrom=wangqianzhou@outlook.com; spf=Pass smtp.helo=postmaster@EUR02-AM5-obe.outbound.protection.outlook.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
  • Spamdiagnosticmetadata: NSPM
  • Spamdiagnosticoutput: 1:99
Hi,
I am trying to factorize a 172-digit number. However, immediately after entering the merging stage, program fails. I have no idea about what to do at the moment. It looks like a  “-maxlevel 40” was given but max level should be less than 32. May I ask for any suggestion to modify the code or otherwise?
Error Info attached below,
Error:Filtering - Merging: Program run on server failed with exit code 1
Error:Filtering - Merging: Command line was: /home/ubuntu/cado-nfs/build/ip-172-31-6-213/filter/merge -mat /tmp/cado.jtfg_n5g/c170.purged.gz -out /tmp/cado.jtfg_n5g/c170.history.gz -maxlevel 40 -keep 160 -skip 32 -target_density 170.0 -t 72 > /tmp/cado.jtfg_n5g/c170.merge.stdout.1 2> /tmp/cado.jtfg_n5g/c170.merge.stderr.1
Error:Filtering - Merging: Stderr output follows (stored in file /tmp/cado.jtfg_n5g/c170.merge.stderr.1):
b'# Warning: parameter verbose_flags is checked by this program but is undocumented.\nError: maxlevel should be positive and less than 32\nUsage: /home/ubuntu/cado-nfs/build/ip-172-31-6-213/filter/merge <parameters>\nThe available parameters are the following:\n    -mat       input purged file\n    -out       output history file\n    -keep      excess to keep (default 160)\n    -skip      number of heavy columns to bury (default 32)\n    -maxlevel  maximum number of rows in a merge (default 10)\n    -target_density stop when the average row density exceeds this value (default 170.0)\n    -resume    resume from history file\n    -mkztype   controls how the weight of a merge is approximated (default 1)\n    -wmstmax   controls until when a mst is used with -mkztype 2 (default 7)\n    -forbidden-cols list of columns that cannot be used for merges\n    -force-posix-threads (switch)\n    -path_antebuffer path to antebuffer program\n    -v         verbose level\n    -t         number of threads\n'
Traceback (most recent call last):
  File "./cado-nfs.py", line 122, in <module>
    factors = factorjob.run()
  File "./scripts/cadofactor/cadotask.py", line 5459, in run
    last_status, last_task = self.run_next_task()
  File "./scripts/cadofactor/cadotask.py", line 5534, in run_next_task
    return [task.run(), task.title]
  File "./scripts/cadofactor/cadotask.py", line 3911, in run
    raise Exception("Program failed")
Exception: Program failed
Yours sincerely,
Terry
