cado-nfs - Re: [Cado-nfs-discuss] Program fails immediately after entering merging
  • To: Wang Qianzhou <wangqianzhou@outlook.com>
  • Cc: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
  • Subject: Re: [Cado-nfs-discuss] Program fails immediately after entering merging
  • Date: Tue, 27 Feb 2018 07:53:21 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Terry,
A few months ago, Paul Zimmermann fixed this problem in commit
15f05df76266a46fde5. If you don't want to take the risk of updating your
local cado-nfs copy and losing your ongoing computation for some
unexpected incompatibility reason, you can just modify the file parameter
parameters/factor/params.c170
and set the value of
tasks.filter.maxlevel
to 30.
This is a local parameter to the merge step that should not interact
badly with the other parts of the computation.
Regards,
Pierrick
On Mon, Feb 26, 2018 at 06:14:47PM +0000, Wang Qianzhou wrote:
> Hi,
> I am trying to factorize a 172-digit number. However, immediately after
> entering the merging stage, program fails. I have no idea about what to do
> at the moment. It looks like a "-maxlevel 40" was given but max level
> should be less than 32. May I ask for any suggestion to modify the code or
> otherwise?
> Error Info attached below,
> Error:Filtering - Merging: Program run on server failed with exit code 1
> Error:Filtering - Merging: Command line was:
> /home/ubuntu/cado-nfs/build/ip-172-31-6-213/filter/merge -mat
> /tmp/cado.jtfg_n5g/c170.purged.gz -out /tmp/cado.jtfg_n5g/c170.history.gz
> -maxlevel 40 -keep 160 -skip 32 -target_density 170.0 -t 72 >
> /tmp/cado.jtfg_n5g/c170.merge.stdout.1 2>
> /tmp/cado.jtfg_n5g/c170.merge.stderr.1
> Error:Filtering - Merging: Stderr output follows (stored in file
> /tmp/cado.jtfg_n5g/c170.merge.stderr.1):
> b'# Warning: parameter verbose_flags is checked by this program but is
> undocumented.\nError: maxlevel should be positive and less than 32\nUsage:
> /home/ubuntu/cado-nfs/build/ip-172-31-6-213/filter/merge <parameters>\nThe
> available parameters are the following:\n -mat input purged file\n
> -out output history file\n -keep excess to keep (default
> 160)\n -skip number of heavy columns to bury (default 32)\n
> -maxlevel maximum number of rows in a merge (default 10)\n
> -target_density stop when the average row density exceeds this value
> (default 170.0)\n -resume resume from history file\n -mkztype
> controls how the weight of a merge is approximated (default 1)\n
> -wmstmax controls until when a mst is used with -mkztype 2 (default 7)\n
> -forbidden-cols list of columns that cannot be used for merges\n
> -force-posix-threads (switch)\n -path_antebuffer path to antebuffer
> program\n -v verbose level\n -t number of threads\n'
> Traceback (most recent call last):
> File "./cado-nfs.py", line 122, in <module>
> factors = factorjob.run()
> File "./scripts/cadofactor/cadotask.py", line 5459, in run
> last_status, last_task = self.run_next_task()
> File "./scripts/cadofactor/cadotask.py", line 5534, in run_next_task
> return [task.run(), task.title]
> File "./scripts/cadofactor/cadotask.py", line 3911, in run
> raise Exception("Program failed")
> Exception: Program failed
> Yours sincerely,
> Terry
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
