- To: ROBERT DUCHATEAU <rjd1212@cox.net>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] RSA-180 Successfully Completed
- Date: Fri, 23 Mar 2018 14:30:52 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Robert,
> I have successfully factored RSA-180 using Git development version 23930bb.
glad to see you have found the same factors as those already known!
https://en.wikipedia.org/wiki/RSA_numbers#RSA-180
> The overall factoring time took a total of 32 days, employing one server &
> nine clients, utilizing an imported poly file to save about 2 days of
> polysieving, in addition to running a total of 88 threads for lattice
> sieving, 16 threads for Krylov/Lingen/Mksol, Linear Algebra stage, & 8
> threads for the sqrt run.
did you use the same polynomial used by Danilov and Popovyan?
It would be nice to compare with the polynomial found by CADO-NFS
(after a few hours of sieving you can get a quite good estimate of the ETA).
> Many thanks for your helpful pointers in factoring this particular RSA
> number
> successfully.
you are welcome.
Paul Zimmermann
- [Cado-nfs-discuss] RSA-180 Successfully Completed, ROBERT DUCHATEAU, 03/23/2018
- Re: [Cado-nfs-discuss] RSA-180 Successfully Completed, paul zimmermann, 03/23/2018
- Message not available
- Re: [Cado-nfs-discuss] RSA-180 Successfully Completed, ROBERT DUCHATEAU, 03/24/2018
