cado-nfs - Re: [Cado-nfs-discuss] RSA-180 Successfully Completed
  • To: paul zimmermann <Paul.Zimmermann@inria.fr>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] RSA-180 Successfully Completed
  • Date: Fri, 23 Mar 2018 21:21:15 -0400 (EDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=rjd1212@cox.net; spf=Pass smtp.mailfrom=rjd1212@cox.net; spf=None smtp.helo=postmaster@eastrmfepo203.cox.net
  • Importance: Medium
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Paul,
1) The reason I factored the previously factored, RSA-180 was because I initially wanted to test the robustness of the program after previously factoring RSA-130 through RSA-170 successfully. Unfortunately, when I got around running RSA-180, I had issues with the official cado-nfs-2.3.0 release. In fact, I had previously ran that very same RSA number 3 times only to have unexpected crashes in the sieving portion, or in the merging phase. That's when I decided to use one of the git versions - which proved to be successful.
2) Re: Danilov/Popovyan poly file - No, unfortunately I overlooked that optimized Danilov/Popovyan poly file for RSA-180, which is currently in the parameters/polynomials directory of the git version, but not in the official cado-nfs-2.3.0 release.
Instead, I used the c180 non RSA poly file. My bad.
Best Regards,
RJD
> On March 23, 2018 at 9:30 AM paul zimmermann <Paul.Zimmermann@inria.fr> wrote:
> Dear Robert,
> > I have successfully factored RSA-180 using Git development version 23930bb.
> glad to see you have found the same factors as those already known!
> https://en.wikipedia.org/wiki/RSA_numbers#RSA-180
> > The overall factoring time took a total of 32 days, employing one server &
> > nine clients, utilizing an imported poly file to save about 2 days of
> > polysieving, in addition to running a total of 88 threads for lattice
> > sieving, 16 threads for Krylov/Lingen/Mksol, Linear Algebra stage, & 8
> > threads for the sqrt run.
> did you use the same polynomial used by Danilov and Popovyan?
> It would be nice to compare with the polynomial found by CADO-NFS
> (after a few hours of sieving you can get a quite good estimate of the ETA).
> > Many thanks for your helpful pointers in factoring this particular RSA number
> > successfully.
> you are welcome.
> Paul Zimmermann
