- To: Roberto Zanasi <zanasi.roberto@fermi.mo.it>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] problem while factoring RSA-129
- Date: Mon, 26 Mar 2018 21:41:07 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Roberto,
maybe there is an issue with the antebuffer program on your computer.
Please try the following:
1) create a file /tmp/antebuffer with the following content:
$ cat /tmp/antebuffer
#!/bin/bash
shift
cat $*
2) run again the dup1 command-line, adding -path_antebuffer /tmp
If that works, you can replace the file
/home/roberto/prova-cado-nfs/cado-nfs/build/voyager/utils/antebuffer
by /tmp/antebuffer, and restart cado-nfs.py.
Paul
PS: the snapshot files are in /tmp/cado.07tjxuxt, you should have
/tmp/cado.07tjxuxt/c130.parameters_snapshot.0, and so on.
- [Cado-nfs-discuss] problem while factoring RSA-129, Roberto Zanasi, 03/25/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, paul zimmermann, 03/26/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, Roberto Zanasi, 03/26/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, Emmanuel Thomé, 03/26/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, Pierrick Gaudry, 03/27/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, Roberto Zanasi, 03/27/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, paul zimmermann, 03/27/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, Emmanuel Thomé, 03/27/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, Emmanuel Thomé, 03/28/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, Roberto Zanasi, 03/28/2018
