- To: paul zimmermann <Paul.Zimmermann@inria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] problem while factoring RSA-129
- Date: Mon, 26 Mar 2018 22:39:22 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
On Mon, Mar 26, 2018 at 09:41:07PM +0200, Paul Zimmermann wrote:
> maybe there is an issue with the antebuffer program on your computer.
> Please try the following:
> 1) create a file /tmp/antebuffer with the following content:
better: ditch antebuffer entirely.
rm -f /home/roberto/prova-cado-nfs/cado-nfs/build/voyager/utils/antebuffer
rm -f /tmp/antebuffer
cado-nfs copes with that.
(incidentally, useing path_antebuffer as pointing to a directory, as Paul
suggests, is marked "legacy" in set_antebuffer_path()).
Now honestly, I'm not sure antebuffer is at fault. (countless times I've
blamed it at first).
Can you please try commit 5a17a43c4 and report again ?
E.
- [Cado-nfs-discuss] problem while factoring RSA-129, Roberto Zanasi, 03/25/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, paul zimmermann, 03/26/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, Roberto Zanasi, 03/26/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, Emmanuel Thomé, 03/26/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, Pierrick Gaudry, 03/27/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, Roberto Zanasi, 03/27/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, paul zimmermann, 03/27/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, Emmanuel Thomé, 03/27/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, Emmanuel Thomé, 03/28/2018
- Re: [Cado-nfs-discuss] problem while factoring RSA-129, Roberto Zanasi, 03/28/2018
