[Cado-nfs-discuss] [HELP] Using cado-nfs for sieving + after sieving (square root and etc) stage only
- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] [HELP] Using cado-nfs for sieving + after sieving (square root and etc) stage only
- Date: Wed, 4 Apr 2018 13:51:03 +0700
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=cannysiska@gmail.com; spf=Pass smtp.mailfrom=cannysiska@gmail.com; spf=None smtp.helo=postmaster@mail-vk0-f42.google.com
- Ironport-phdr: 9a23:kc6ZTxMfOuYDnBBekTEl6mtUPXoX/o7sNwtQ0KIMzox0Lfj/rarrMEGX3/hxlliBBdydt6ofzbKO+4nbGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2aFLduGC94iAPERvjKwV1Ov71GonPhMiryuy+4ZLebxlGiTanfb9+MAi9oBnMuMURnYZsMLs6xAHTontPdeRWxGdoKkyWkh3h+Mq+/4Nt/jpJtf45+MFOTav1f6IjTbxFFzsmKHw65NfqtRbYUwSC4GYXX3gMnRpJBwjF6wz6Xov0vyDnuOdxxDWWMMvrRr0yRD+s7bpkSAXwhSkHOTA383zZhNJsg69Auh2tuwZyzpTIbI2JNvdzeL7Wc9MARWpGW8ZcTzBODZm6b4sJD+sKIOlYoJf6p1sUohu+BA+sC/nywTJPmnD5x6s60+IhEAHd3QwgBNEOv27PodX6MacdS+G1zK3SwTrfaPNW3C7w5Y7VeR4iufGBRax8fdbVxEU1FA7Ijk+cpZL4Mz6bzOgAvHaX4ux9Xuy1kWEnsRt+oj23y8cslIbJgoUVx0jB9SpjwYY1IcS0SFB4YdK4CZdQuS6XO5VsTsMtRGFovyk6yrkYtpKhYCcKz5Enywbea/yBbYeI/gruWPiNLTp8nn5oe7Kyiwys/US9xODwTMa53EhSoipAiNbMt3QN1xLJ6siAT/tw5luu1iyJ1wDV6uBEOkE0lbHYK5E72bMwmZ8Tvl7CHi/ygkn5kKiWdkA89uiy9+vneqnmpoObN4Jslg7xKLkhmsumDeQ+PAgORHGX9vm91L344UL5Xa5KjuYtn6ndsZDaPtgbprWjDw9a3IYj7Ay/Dzi439gCnHkHKkhFeBOdgITzNVHOOqOwMfDqiF2gl3JtyeuDMrz6CYjWNVDHkaz9ZvBy5UlGxwd1zNZF5psSBKtSDuj0Xxr6vdreH1c2PguuzOfhAZ0p3YoYX3OUA7SaOYvdtFaJ4qQkJOzaN9xdgyr0N/Vwv62mtnQ+g1JIJfD4j6tSU2ixG7FdG2vcZHPthtkbFmJT51gxSeXrjBuJVjsBPi/uDZJ53SkyDcedNamGXpqk2eXT0yKyH5kQbWdDWAjVTCXYMr6cUvJJUxq8Z89sljteCOqkQo4lkA+t7Er0l+AhIe3T9SkV85nk0Yot6g==
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi, I am interested in evaluating the performance of personally-generated polynomial in real NFS.
I've tested the CADO-NFS software and it works out great. But, I somehow want to use it for polynomial testing.
I have generated them (the polynomials) somehow using the development of Montgomery's method and want to test it out.
Is there some way to test them using CADO-NFS? However, testing using CADO will be starting from sieving instead of poly. selection (because the poly, is obtained already)
Thank you.
- [Cado-nfs-discuss] [HELP] Using cado-nfs for sieving + after sieving (square root and etc) stage only, canny georgina, 04/04/2018
- Re: [Cado-nfs-discuss] [HELP] Using cado-nfs for sieving + after sieving (square root and etc) stage only, paul zimmermann, 04/04/2018
