cado-nfs - Re: [Cado-nfs-discuss] [HELP] Using cado-nfs for sieving + after sieving (square root and etc) stage only
  • To: canny georgina <cannysiska@gmail.com>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] [HELP] Using cado-nfs for sieving + after sieving (square root and etc) stage only
  • Date: Wed, 04 Apr 2018 09:34:52 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi,
> Hi, I am interested in evaluating the performance of personally-generated
> polynomial in real NFS.
> I've tested the CADO-NFS software and it works out great. But, I somehow
> want
> to use it for polynomial testing.
> I have generated them (the polynomials) somehow using the development of
> Montgomery's method and want to test it out.
> Is there some way to test them using CADO-NFS? However, testing using CADO
> will be starting from sieving instead of poly. selection (because the poly,
> is obtained already)
I'm not sure what you mean by "test it out" but there are 2 ways you can test
polynomials you have generated:
1) you can compute their Murphy-E score and compare it with the one of
polynomials generated by CADO-NFS (or other polynomials), for example:
$ ./build/tomate/polyselect/rotate -Bf 30940618 -Bg 17246818 -I 14 -skew
10800 parameters/polynomials/rsa155.poly 0 0
n:
10941738641570527421809707322040357612003732945449205990913842131476349984288934784717997257891267332497625752899781833797076537244027146743531593354333897
Y1: 1
Y0: -39123079721168000771313449081
c5: 119377138320
c4: -80168937284997582
c3: -66269852234118574445
c2: 11816848430079521880356852
c1: 7459661580071786443919743056
c0: -40679843542362159361913708405064
skew: 10800.000
# lognorm: 50.44, alpha: -6.23 (proj: -2.36), E: 44.21, nr: 5
# MurphyE(Bf=3.094e+07,Bg=1.725e+07,area=4.153e+15)=5.28e-11
# generated by 3d09b51cc: 10800 parameters/polynomials/rsa155.poly 0 0 in
0.01s
The higher the Murphy-E score is (here 5.28e-11), the better the polynomial
is. Make sure to use the same Bf/Bg/I parameters when comparing two
polynomial pairs, and to provide a correct skewness (if no skewness is given
in the file, it will be automatically computed by CADO-NFS).
However, this method does only work for polynomial pairs with the same
degrees.
2) you can perform a sieving test with CADO-NFS, for example by importing the
polynomial you have generated. See scripts/cadofactor/README. Then the ETA
printed by CADO-NFS will indicate how good is your polynomial.
Best regards,
Paul Zimmermann
