- To: "cado-nfs-discuss" <cado-nfs-discuss@lists.gforge.inria.fr>
- Subject: [Cado-nfs-discuss] DLP: Required qmin not found
- Date: Sat, 1 Dec 2018 21:47:54 +0800
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=sfvsfgvs@foxmail.com; spf=Pass smtp.mailfrom=sfvsfgvs@foxmail.com; spf=Pass smtp.helo=postmaster@smtpbg63.qq.com
- Feedback-id: webmail:foxmail.com:bgweb:bgweb116
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello everyone,
I'm trying to execute something like:
./cado-nfs.py -dlp -ell 481006989528686211893 target=2410497055970432881345493397846112198995088771364307195189734031205605186951241875096796459061741781667380437076874705300974836586165283741668656930807264789 5682549022748424631339131913370125786212509227588493537874673173634936008725904358935442101466555561124455782847468955028529037660533553941399408331331403379
(In this case p is a 157-digit prime)
And immediately there raises a problem:
Critical:Parameters: Required parameter qmin not found under path tasks.polyselect
Traceback (most recent call last):
File "./cado-nfs.py", line 116, in <module>
path_prefix = [])
File "./scripts/cadofactor/cadotask.py", line 5591, in __init__
path_prefix=polyselpath)
File "./scripts/cadofactor/cadotask.py", line 2196, in __init__
path_prefix=path_prefix)
File "./scripts/cadofactor/cadotask.py", line 1491, in __init__
File "./scripts/cadofactor/cadotask.py", line 1052, in __init__
self.params = self.parameters.myparams(self.paramnames)
File "./scripts/cadofactor/cadoparams.py", line 789, in myparams
return self.parameters.myparams(keys, path)
File "./scripts/cadofactor/cadoparams.py", line 169, in myparams
self._convert_types(result, keys, splitpath, found_at_path)
File "./scripts/cadofactor/cadoparams.py", line 626, in _convert_types
raise KeyError(msg)
KeyError: 'Required parameter qmin not found under path tasks.polyselect'
path_prefix = [])
raise KeyError(msg)
What can I do to make it execute correctly?
Thanks a lot!
Best regards,
Lao Fenxia
- [Cado-nfs-discuss] DLP: Required qmin not found, fc-canton, 12/01/2018
- Re: [Cado-nfs-discuss] DLP: Required qmin not found, Pierrick Gaudry, 12/03/2018
