cado-nfs - Re: [Cado-nfs-discuss] DLP: Required qmin not found
  • To: fc-canton <sfvsfgvs@foxmail.com>
  • Cc: cado-nfs-discuss <cado-nfs-discuss@lists.gforge.inria.fr>
  • Subject: Re: [Cado-nfs-discuss] DLP: Required qmin not found
  • Date: Mon, 3 Dec 2018 07:47:49 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi Lao,
There has been some change that now imposes that a parameter tasks.qmin
be present in the param files, but somehow the params.p155 file was not
modified accordingly. Thanks for reporting.
This can be fixed by adding the following line to the parameter file:
tasks.qmin = 15000000
(and I will commit the change to the repo)
Regards,
Pierrick
On Sat, Dec 01, 2018 at 09:47:54PM +0800, fc-canton wrote:
> Hello everyone,
> I'm trying to execute something like:
> ./cado-nfs.py -dlp -ell 481006989528686211893
> target=2410497055970432881345493397846112198995088771364307195189734031205605186951241875096796459061741781667380437076874705300974836586165283741668656930807264789
> 5682549022748424631339131913370125786212509227588493537874673173634936008725904358935442101466555561124455782847468955028529037660533553941399408331331403379
> (In this case p is a 157-digit prime)
> And immediately there raises a problem:
> Critical:Parameters: Required parameter qmin not found under path
> tasks.polyselect
> Traceback (most recent call last):
> File "./cado-nfs.py", line 116, in <module>
> path_prefix = [])
> File "./scripts/cadofactor/cadotask.py", line 5591, in __init__
> path_prefix=polyselpath)
> File "./scripts/cadofactor/cadotask.py", line 2196, in __init__
> path_prefix=path_prefix)
> File "./scripts/cadofactor/cadotask.py", line 1491, in __init__
> File "./scripts/cadofactor/cadotask.py", line 1052, in __init__
> self.params = self.parameters.myparams(self.paramnames)
> File "./scripts/cadofactor/cadoparams.py", line 789, in myparams
> return self.parameters.myparams(keys, path)
> File "./scripts/cadofactor/cadoparams.py", line 169, in myparams
> self._convert_types(result, keys, splitpath, found_at_path)
> File "./scripts/cadofactor/cadoparams.py", line 626, in _convert_types
> raise KeyError(msg)
> KeyError: 'Required parameter qmin not found under path tasks.polyselect'
> What can I do to make it execute correctly?
> Thanks a lot!
> Best regards,
> Lao Fenxia
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
