cado-nfs - Re: [Cado-nfs-discuss] return code -6 , exit code -6
  • To: eric.jeancolas@free.fr
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] return code -6 , exit code -6
  • Date: Wed, 20 Feb 2019 21:56:28 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Eric,
> I use cado-nfs-2.3.0 for factoring c120 to c160 numbers.
> It has always been working fine for about 30 numbers so far.
great!
> This is the first time I get an error. [...]
> Any other idea to understand what's going on?
it seems the file dup1.0.0000.gz is corrupted. You can try to rebuild it
as follows:
1) look in /tmp/cado.qnpox55b for a file named c140.dup1.stdout.1.
Copy and execute the first line from this file (after # (2acb184f4)).
This should create again the file dup1.0.0000.gz. You can then check it is
valid with gzip -t.
2) restart the factorization with:
cado-nfs.py /tmp/cado.qnpox55b/c140.parameters_snapshot.0
If this does not work, please tell us.
Paul Zimmermann
