cado-nfs - [Cado-nfs-discuss] Fwd: return code -6 , exit code -6
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: [Cado-nfs-discuss] Fwd: return code -6 , exit code -6
  • Date: Thu, 21 Feb 2019 09:49:37 +0100 (CET)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=eric.jeancolas@free.fr; spf=None smtp.mailfrom=eric.jeancolas@free.fr; spf=None smtp.helo=postmaster@smtp3-g21.free.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Whaoo, thank you for your responsiveness.
I don't know why the file was corrupted when built. An I/O check, a neutrino
that hit my CPU, or whatsoever...
After your instructions, the file was not corrupted any longer.
But when I restarted, I got another error further (see stdout hereunder)
Maybe because I made several tests before I sent you my feedback.
Or maybe because I have another factorization running.
Anyway I will rerun the factorization from scratch.
As I have another factorization running, I will not be able to give you any
feedback before next Wednesday.
Best regards.
./cado-nfs.py /tmp/cado.qnpox55b/c140.parameters_snapshot.0
Info:root: No database exists yet
Info:Database: Opened connection to database /tmp/cado.qnpox55b/c140.db
Info:root: tasks.polyselect.threads = 2
Info:root: tasks.sieve.las.threads = 2
Info:root: Command line parameters: ./cado-nfs.py
Info:root: If this computation gets interrupted, it can be resumed with
./cado-nfs.py /tmp/cado.qnpox55b/c140.parameters_snapshot.2
Info:Server Launcher: Adding ng-All-Series to whitelist to allow clients on
localhost to connect
Info:HTTP server: Using non-threaded HTTPS server
Info:HTTP server: Using whitelist: localhost,ng-All-Series
Info:Complete Factorization: Factoring
114092790024322036665919359655432984163277313962134547254404440195422458391584434451220692010515202678454628424122139839393927744958571074477
Warning:Complete Factorization: The start time of the last cado-nfs.py run
was recorded, but not its end time, maybe because it died unexpectedly.
Warning:Complete Factorization: Elapsed time of last run is not known and
will not be counted towards total.
Info:HTTP server: serving at https://ng-All-Series:33927 (0.0.0.0)
Info:HTTP server: For debugging purposes, the URL above can be accessed if
the server.only_registered=False parameter is added
Info:HTTP server: You can start additional cado-nfs-client.py scripts with
parameters: --server=https://ng-All-Series:33927
--certsha1=16320c277442762847795111a151213b1524ce0e
Info:HTTP server: If you want to start additional clients, remember to add
their hosts to server.whitelist
Info:Client Launcher: Client localhost on host localhost with PID 21750
already running
Info:Client Launcher: Client localhost+2 on host localhost with PID 21753
already running
Info:Client Launcher: Client localhost+3 on host localhost with PID 21756
already running
Info:Client Launcher: Client localhost+4 on host localhost with PID 21759
already running
Info:Client Launcher: Client localhost+5 on host localhost with PID 21762
already running
Info:Client Launcher: Client localhost+6 on host localhost with PID 21765
already running
Info:Client Launcher: Running clients: localhost (Host localhost, PID 21750),
localhost+2 (Host localhost, PID 21753), localhost+3 (Host localhost, PID
21756), localhost+4 (Host localhost, PID 21759), localhost+5 (Host localhost,
PID 21762), localhost+6 (Host localhost, PID 21765)
Info:Polynomial Selection (size optimized): Starting
Info:Polynomial Selection (size optimized): 100 polynomials in queue from
previous run, worst lognorm 37.740000
Info:Polynomial Selection (size optimized): Already finished - nothing to do
Info:Polynomial Selection (size optimized): Aggregate statistics:
Info:Polynomial Selection (size optimized): potential collisions: 65655.1
Info:Polynomial Selection (size optimized): raw lognorm (nr/min/av/max/std):
66463/42.200/50.441/55.590/0.953
Info:Polynomial Selection (size optimized): optimized lognorm
(nr/min/av/max/std): 66463/40.800/45.220/51.110/1.323
Info:Polynomial Selection (size optimized): Total time: 60621.7
Info:Polynomial Selection (root optimized): Starting
Info:Polynomial Selection (root optimized): Best polynomial previously found
in /tmp/cado.qnpox55b/c140.upload/c140.polyselect2.yguiwty8.opt_48 has
Murphy_E = 7.5e-10
Info:Polynomial Selection (root optimized): Already finished - nothing to do
Info:Polynomial Selection (root optimized): Best overall polynomial was 3-th
in list after size optimization
Info:Polynomial Selection (root optimized): Aggregate statistics:
Info:Polynomial Selection (root optimized): Total time: 11336.6
Info:Polynomial Selection (root optimized): Rootsieve time: 11333.9
Info:Generate Factor Base: Starting
Info:Generate Factor Base: Total cpu/real time for makefb: 23.31/2.83168
Info:Generate Free Relations: Starting
Info:Generate Free Relations: Total cpu/real time for freerel: 411.3/37.4115
Info:Lattice Sieving: Starting
Info:Lattice Sieving: We want 25172582 relations
Info:Lattice Sieving: Reached target of 25172582 relations, now have 25440595
Info:Lattice Sieving: Aggregate statistics:
Info:Lattice Sieving: Total number of relations: 25440595
Info:Lattice Sieving: Average J: 3793.09 for 954185 special-q, max bucket
fill: 0.688696
Info:Lattice Sieving: Total CPU time: 2.67465e+06s
Info:Filtering - Duplicate Removal, splitting pass: Starting
Info:Filtering - Duplicate Removal, splitting pass: No new files to split
Info:Filtering - Duplicate Removal, splitting pass: Relations per slice: 0:
12723950, 1: 12716645
Info:Filtering - Duplicate Removal, splitting pass: Total cpu/real time for
dup1: 191.17/376.338
Info:Filtering - Duplicate Removal, splitting pass: Aggregate statistics:
Info:Filtering - Duplicate Removal, splitting pass: CPU time for dup1: 375.6s
Info:Filtering - Duplicate Removal, removal pass: Starting
Info:Filtering - Duplicate Removal, removal pass: No new files for slice 0,
nothing to do
Info:HTTP server: 127.0.0.1 Sending workunit c140_sieving_26170000-26180000
to client localhost+2
Info:HTTP server: 127.0.0.1 Sending workunit c140_sieving_26180000-26190000
to client localhost+3
Info:HTTP server: 127.0.0.1 Sending workunit c140_sieving_26190000-26200000
to client localhost
Info:Filtering - Duplicate Removal, removal pass: 10579655 unique relations
remain on slice 1
Info:Filtering - Duplicate Removal, removal pass: Of 258952 newly added
relations 199791 were unique (ratio 0.771537)
Info:Filtering - Duplicate Removal, removal pass: 21166842 unique relations
remain in total
Info:Filtering - Duplicate Removal, removal pass: Total cpu/real time for
dup2: 1174.13/1031.1
Info:Filtering - Singleton removal: Starting
Info:Filtering - Singleton removal: Reading 21166842 unique and 121591 free
relations, total 21288433
Warning:Command: Process with PID 3611 finished with return code -11
Traceback (most recent call last):
File "./cado-nfs.py", line 122, in <module>
factors = factorjob.run()
File "./scripts/cadofactor/cadotask.py", line 5429, in run
last_status, last_task = self.run_next_task()
File "./scripts/cadofactor/cadotask.py", line 5504, in run_next_task
return [task.run(), task.title]
File "./scripts/cadofactor/cadotask.py", line 3503, in run
stats = self.parse_stdout(stdout)
File "./scripts/cadofactor/cadotask.py", line 3653, in parse_stdout
(self.title, self.programs[0][0].name, final_values_line))
Exception: Filtering - Singleton removal: output of purge did not contain
'Final values:'
----- Mail original -----
De: "paul zimmermann" <Paul.Zimmermann@inria.fr>
À: "eric jeancolas" <eric.jeancolas@free.fr>
Cc: cado-nfs-discuss@lists.gforge.inria.fr
Envoyé: Mercredi 20 Février 2019 21:56:28
Objet: Re: [Cado-nfs-discuss] return code -6 , exit code -6
Dear Eric,
> I use cado-nfs-2.3.0 for factoring c120 to c160 numbers.
> It has always been working fine for about 30 numbers so far.
great!
> This is the first time I get an error. [...]
> Any other idea to understand what's going on?
it seems the file dup1.0.0000.gz is corrupted. You can try to rebuild it
as follows:
1) look in /tmp/cado.qnpox55b for a file named c140.dup1.stdout.1.
Copy and execute the first line from this file (after # (2acb184f4)).
This should create again the file dup1.0.0000.gz. You can then check it is
valid with gzip -t.
2) restart the factorization with:
If this does not work, please tell us.
Paul Zimmermann
