cado-nfs - Re: [Cado-nfs-discuss] Fwd: return code -6 , exit code -6
  • To: paul zimmermann <Paul.Zimmermann@inria.fr>
  • Cc: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: Re: [Cado-nfs-discuss] Fwd: return code -6 , exit code -6
  • Date: Thu, 21 Feb 2019 11:56:28 +0100 (CET)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=eric.jeancolas@free.fr; spf=None smtp.mailfrom=eric.jeancolas@free.fr; spf=None smtp.helo=postmaster@smtp4-g21.free.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
I got 3 c140.purge.stdout.x
x=1: seems complete
x=2 and x=3: seems interrupted.
I send you the three of them.
cat c140.purge.stdout.1
# (2acb184f4) /home/ng/cado-nfs-2.3.0/build/ng-All-Series/filter/purge -out
/tmp/cado.qnpox55b/c140.purged.gz -nrels 21088642 -keep 160 -col-min-index
731455 -col-max-index 29258219 -t 12 -required_excess 0.0
/tmp/cado.qnpox55b/c140.dup1//0/dup1.0.0000.gz
/tmp/cado.qnpox55b/c140.dup1//1/dup1.0.0000.gz
/tmp/cado.qnpox55b/c140.freerel.gz
# List of modified files in working directory and their SHA1 sum:
# (tarball extracted)
# Compiled with gcc 4.8.4
# Compilation flags -std=c99 -g -W -Wall -O2 -msse3 -mssse3 -msse4.1 -mavx
-mavx2 -mpclmul
Weight function used during clique removal:
0 1 2 3 4 5 6 7
0.000 0.000 0.125 0.800 0.640 0.512 0.410 0.328
# INFO: number of rows: 21088642
# INFO: maximum possible index of a column: 29258219
# INFO: number of threads: 12
# INFO: number of clique removal steps: will be chosen by the program
# INFO: target excess: 160
# MEMORY: Allocated cols_weight of 27MB (total 27MB so far)
# MEMORY: Allocated sum2_row of 223MB (total 251MB so far)
# MEMORY: Allocated row_compact of 160MB (total 412MB so far)
Pass 1, reading and storing columns with index h >= 731455
# Read 1024 relations in 0.1s -- 1.4 MB/s -- 13598.8 rels/s
# Read 2048 relations in 0.1s -- 2.7 MB/s -- 26715.1 rels/s
# Read 4096 relations in 0.1s -- 5.2 MB/s -- 51626.5 rels/s
# Read 8192 relations in 0.1s -- 7.5 MB/s -- 73537.5 rels/s
# Read 16384 relations in 0.2s -- 10.2 MB/s -- 100143.1 rels/s
# Read 32768 relations in 0.3s -- 12.9 MB/s -- 126818.5 rels/s
# Read 65536 relations in 0.4s -- 16.3 MB/s -- 160033.2 rels/s
# Read 131072 relations in 0.7s -- 18.9 MB/s -- 185886.6 rels/s
# Read 262144 relations in 1.4s -- 19.2 MB/s -- 188571.8 rels/s
# Read 524288 relations in 3.1s -- 17.1 MB/s -- 167596.7 rels/s
# Read 1048576 relations in 6.7s -- 15.8 MB/s -- 155352.4 rels/s
# Read 2097152 relations in 14.5s -- 14.8 MB/s -- 144957.9 rels/s
# Read 4194304 relations in 29.4s -- 14.6 MB/s -- 142734.8 rels/s
# Read 8388608 relations in 57.7s -- 14.9 MB/s -- 145303.3 rels/s
# Read 16777216 relations in 112.9s -- 15.2 MB/s -- 148621.2 rels/s
# Done: Read 21088642 relations in 141.0s -- 15.3 MB/s -- 149533.4 rels/s
# MEMORY: Allocated row_compact[i] 460MB (total 872MB so far)
Step 0: only singleton removal
Sing. rem.: begin with: nrows=21088642 ncols=22852402 excess=-1763760 at 47.52
Sing. rem.: iter 001: nrows=13265354 ncols=13493344 excess=-227990 at 50.41
Sing. rem.: iter 002: nrows=10928497 ncols=10970246 excess=-41749 at 52.05
Sing. rem.: iter 003: nrows=10081254 ncols=10094451 excess=-13197 at 53.19
Sing. rem.: iter 004: nrows=9729466 ncols=9737430 excess=-7964 at 54.20
Sing. rem.: iter 005: nrows=9581682 ncols=9588715 excess=-7033 at 55.28
Sing. rem.: iter 006: nrows=9518630 ncols=9525508 excess=-6878 at 56.25
Sing. rem.: iter 007: nrows=9490827 ncols=9497680 excess=-6853 at 57.23
Sing. rem.: iter 008: nrows=9477899 ncols=9484743 excess=-6844 at 58.22
Sing. rem.: iter 009: nrows=9471917 ncols=9478760 excess=-6843 at 59.14
Sing. rem.: iter 010: nrows=9469194 ncols=9476037 excess=-6843 at 60.12
Sing. rem.: iter 011: nrows=9467993 ncols=9474836 excess=-6843 at 61.11
Sing. rem.: iter 012: nrows=9467493 ncols=9474336 excess=-6843 at 62.09
Sing. rem.: iter 013: nrows=9467248 ncols=9474091 excess=-6843 at 63.02
Sing. rem.: iter 014: nrows=9467121 ncols=9473964 excess=-6843 at 64.03
Sing. rem.: iter 015: nrows=9467072 ncols=9473915 excess=-6843 at 65.06
Sing. rem.: iter 016: nrows=9467062 ncols=9473905 excess=-6843 at 66.04
Sing. rem.: iter 017: No more singletons, finished at 66.90
number of rows < number of columns + keep
Final values:
weight=0 weight*nrows=0.00e+00
cat c140.purge.stdout.2
/tmp/cado.qnpox55b/c140.purged.gz -nrels 21288433 -keep 160 -col-min-index
/tmp/cado.qnpox55b/c140.dup1//0/dup1.1.0000.gz
/tmp/cado.qnpox55b/c140.dup1//1/dup1.1.0000.gz
-mavx2 -mpclmul
0 1 2 3 4 5 6 7
# INFO: number of rows: 21288433
# MEMORY: Allocated row_compact of 162MB (total 413MB so far)
# Read 1024 relations in 0.0s -- 5.2 MB/s -- 41836.8 rels/s
# Read 2048 relations in 0.0s -- 9.8 MB/s -- 79011.9 rels/s
cat c140.purge.stdout.3
-mavx2 -mpclmul
0 1 2 3 4 5 6 7
# Read 1024 relations in 0.1s -- 1.7 MB/s -- 13736.3 rels/s
Eric
----- Mail original -----
De: "paul zimmermann" <Paul.Zimmermann@inria.fr>
À: "eric jeancolas" <eric.jeancolas@free.fr>
Envoyé: Jeudi 21 Février 2019 10:10:02
Objet: Re: [Cado-nfs-discuss] Fwd: return code -6 , exit code -6
Dear Eric,
> But when I restarted, I got another error further (see stdout hereunder)
please can you send the content of the file c140.purge.stdout.1?
I already got the error "output of purge did not contain 'Final values:'"
when mixing several versions of CADO-NFS.
Paul
