- From: Aurore Guillevic <guillevic@lix.polytechnique.fr>
- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] DLP computations in GF(p^2)
- Date: Wed, 15 Apr 2020 23:31:06 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=guillevic@lix.polytechnique.fr; spf=Pass smtp.mailfrom=guillevic@lix.polytechnique.fr; spf=None smtp.helo=postmaster@mx-a.polytechnique.fr
- Ironport-phdr: 9a23:nUTHDR1XWm1xA5r7smDT+DRfVm0co7zxezQtwd8ZseMeL/ad9pjvdHbS+e9qxAeQG9mCtrQf0KGP7/GoGTRZp8rY7DZaKN0EfiRGoPtVtjRoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdaz6FYHIksu4yf259YHNbAVUnjq9Zq55IAmroQnLucQanItvJrw/xxbHrXdEZutbyGd1Ll6Xgxrw+9288ZF+/ylfof4t69JMXaDndKkkULJUCygrPG8y6MD3rxfIUBGB5mEbUmUYkxpIBxbK4RTnVZrvsSX0q/Rw1jCCMcL5Ub47VzKi77x2SBDzkycIKyQ58GDMhcNuiq9QvQ+sqAZ+w47QZ4GVKeZ+c6bAdt4UWWZNQsBcXDFHD4ihbYUAEvABMP5FoYfjqVsArRiwCweiC+zgyDBHmmT70rcm3+k7CwzKwAItEtAIvX/JrNv1LqASUeWtwaTU0DXDdfRW2S3j54PVcx4hvPCMXbZ0ccXP10kvFh/KhUiXpIzqIjOV1+ANs2yF4Op+VOKgl3UqqwVwojmg3Mssko7JhoYVy1DY6yp23IY1Jdu5SE5ifN6rDoFcty+AN4ZvRM4pXm9muCE/yrIcuJ67ejAHx4g9yBHCbPyLao6I4hz4VOqLOTd5hGppeLa4hxao8Eiv0PfwVseu0FpSsyVKjMLMuWwT2BzV9siLUON9/0e51TaO0QDT8OBELloumarVMZ4sxKM7mJkLsUnbAyP6hkH7gLWLekk49eWk8erqbqn8qpOBOIJ4kgXzPrg0lsG7AOk0KAcDUmuB9eii2rDu8kv0S6hQgPIsiKnWqpXaKNwbpqGnBw9V1Z4u6xOwDju/ytsUh2EHLFVBeBOHk4jmJU3BIPD+Dfe+mlSsjSlky+rIPr37GpnNL37Dn6n9fbtl9kJQ1g4+wcpC655IBbwNOvz+VlPruNDFARI1Kwm0zPzmCNV52IMeQ2WPAqqBPaPdrF+I5+YvI+2Sa48LuTbyN+Mo5/rvjX42g1MdZa6p3Z8XaXCkAPtpP0WZYXztgtcYDGcFoBAyTOLwiFGaSz5ce26yX74g5jE8EI+pEZ3MSZ2qgLCY2ie7EIZWanlbBVCNCnfna5iEW+wXaC+JJs9hkycEVaS6S4M72hGuugj6y6BoLuXK4CEYtJTj1MJ05+LJjx0y+yZ0XIyh1DSGRm1z22UGXHo63bt0vFdm4lOCyrRjxfNWEsZc6rVIVB07PNjS1b9UEdf3DyvcZNCTRR6JX9SiBTwvT9l5l9ATYkJ5FsujhTjH3jrsG7gRhqCGD5wy87vB0j7/PZAumD79yKA9ggx+EYN0Pmq8i/snrlSBN8vyi0yc0p2SW+EExieXrjWHzHrIpEZcQRJ9WqXDXGkCaw3Yt4ahvxKQf/qVEb0idzB554uHI6pOZMfuiA8cFvPiKJLGZGagh2q7BRCJ366BKoTwKTxEgXftTXMcmgVWxk6ocAgzAiD7+DDbHHlnU0roZ1Lw/OJ+rnKiU0JywRvYN0A=
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hi,
Here is a possible explanation : the irreducible polynomial that
defines the quadratic extension GF(p^2) over GF(p) is not the same
in PARI-gp and in cado-nfs.
In PARI:
p = 262086107969265031
ell = 32760763496158129 \\ (largest prime factor of p^2 - 1)
c = ffgen([p,2], X)
g=216232938003097459*c + 190041067314658365
target=117385794987197527*c + 235757958534339998
exponent=11818731183008556
c.mod \\ will print the irreducible polynomial P(x): this is x^2 +
x - 4 = x^2 + x + 262086107969265027
fforder(g) == ell
g^exponent == target
In cado-nfs:
the command is
cado-nfs/cado-nfs.py 262086107969265031 -dlp -ell
32760763496158129 -gfpext 2 --workdir=/data/cado-nfs/test
The irreducible polynomial to define GF(p^2) is given in a file
p2dd20.py (in /data/cado-nfs/test)
cat p2dd20.poly # (this file is generated at the beginning of the
command)
n: 262086107969265031
skew: 1.0
# f
poly0: 1,0,0,0,1
# f lognorm -0.49, skew 1.00, alpha 2.63, E 2.14, exp_E -0.49
# g
poly1: 1529428992,-472061699,1529428992
# g lognorm 21.18, skew 1.00, alpha -0.31, E 20.87, exp_E 21.18
# gcd(f, g) = phi = 1,-34471592128557630,1
the last line is important: the polynomial is named phi.
phi = 1 -34471592128557630*x + x^2
This is not the same as in PARI-GP. A conversion into this
representation is needed.
/data/cado-nfs/test/p2dd20.parameters_snapshot.0
target=216232938003097459,190041067314658365
the problem is the representation of the target. It is given
modulo x^2 + x - 4, but we would like to use phi.
T = Mod(1,p)*phi
P = c.mod
R = polrootsff(T, p, P)[1]
\\ To map something mod phi to mod P, we have xi =
60470699907903726*c + 47471146018230678
\\ To map something mod P to mod phi, we have (xi -
47471146018230678)/60470699907903726 = c
u = 1/Mod(60470699907903726,p)
v = - 47471146018230678 * u
xi = 60470699907903726*c + 47471146018230678
c == 10171266721348391*xi + 212219866433972631
now, generator is g = 216232938003097459*c + 190041067314658365
(216232938003097459,190041067314658365)
this is 216232938003097459*(10171266721348391*xi +
212219866433972631) + 190041067314658365
Mod(216232938003097459,p)*(Mod(10171266721348391,p)*XI +
Mod(212219866433972631,p)) + Mod(190041067314658365,p)
%23 = Mod(72670631844203435, 262086107969265031)*XI +
Mod(102945478732893391, 262086107969265031)
Consequently we need to give
(72670631844203435,102945478732893391) to cado-nfs
Target is
this becomes
C = Mod(10171266721348391,p)*XI + Mod(212219866433972631,p)
Mod(117385794987197527,p)*C + Mod(235757958534339998,p)
Mod(254505989833957736, 262086107969265031)*XI +
Mod(87040225854068861, 262086107969265031)
and we need to give (254505989833957736,87040225854068861) to
cado-nfs
Maybe you could try the following:
target=72670631844203435,102945478732893391
target=254505989833957736,87040225854068861
And also, clearing the cofactor (p^2-1)/ell is needed to obtain
exact equality.
For the examples you have (the following is in Sage):
ell = 32760763496158129 # (largest prime factor of p^2 - 1)
cofact = (p^2 -1)//ell # this is 2096688863754120240, that is,
(p-1)*8
Fl = GF(ell)
Fp = GF(p)
Fpx.<X> = Fp[]
phi = 1 -34471592128557630*X + X^2
Fp2.<x> = Fp.extension(phi)
target1=216232938003097459*x + 190041067314658365
log1 = 13394876329845831
target2=117385794987197527*x + 235757958534339998
log2 = 30091716292081506
(target1^log2)^cofact == (target2^log1)^cofact
(target1^(Fl(log2/log1)))^cofact == target2^cofact
Your logarithms are correct, but the elements (target1 and target2) are expressed in an extension defined by phi = X^2-34471592128557630*X+1.
Best regards,
Aurore.
Aurore Guillevic Chargée d'enseignement, École Polytechnique Bâtiment Turing, bureau 2042, Palaiseau Chargée de recherche Inria Équipe Caramba, bureau B258 Inria Nancy -- Grand Est 615 rue du jardin botanique, CS 20101 54603 Villers-lès-Nancy Cedex France https://members.loria.fr/AGuillevic/
Info:root: log(target) = 13394876329845831
Info:root: log(target) = 30091716292081506
_______________________________________________ Cado-nfs-discuss mailing list Cado-nfs-discuss@lists.gforge.inria.fr https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
- [Cado-nfs-discuss] DLP computations in GF(p^2), Filip Fifka, 04/15/2020
- Re: [Cado-nfs-discuss] DLP computations in GF(p^2), Aurore Guillevic, 04/15/2020
- Re: [Cado-nfs-discuss] DLP computations in GF(p^2), Filip Fifka, 04/16/2020
- Re: [Cado-nfs-discuss] DLP computations in GF(p^2), Pierrick Gaudry, 04/16/2020
- Re: [Cado-nfs-discuss] DLP computations in GF(p^2), Filip Fifka, 04/17/2020
- Re: [Cado-nfs-discuss] DLP computations in GF(p^2), Pierrick Gaudry, 04/17/2020
