- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: [Cado-nfs-discuss] DLP computations in GF(p^2)
- Date: Wed, 15 Apr 2020 14:17:07 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=filip.fifka@gmail.com; spf=Pass smtp.mailfrom=filip.fifka@gmail.com; spf=None smtp.helo=postmaster@mail-ot1-f42.google.com
- Ironport-phdr: 9a23:kPbp9xIdIYOT6IUL29mcpTZWNBhigK39O0sv0rFitYgXLfvxwZ3uMQTl6Ol3ixeRBMOAtKIC1rKempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBWB6kG1uDUbFhK6MwRuY+j0AYXPlN+f0+Gp54aVbAtPnjWwJ7J0NhS/6wvL5ecMho43BKc1ywOBjHpGeO0ekW1pIVOL2Rj96MS51JFm+iVU/fkm8pgTAu3BY60kQOkAX3wdOGcv6Ziz7ESRfU60/nIZF14uvF9IDgzCtkyoW57wtm79qrM41nXAe8LxSr8wVHKp6KI5EEa02hdCDCYw9STssuI1lLhS+UvzqBl2woqSa4aQZqInL/HtOOgCTG8EZf5/EilIA4eydYwKVrNTMuNRro27rFwL/0Kz
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello,
I'm trying to compute discrete logarithms in GF(p^2) as outlined by the last section of README.dlp (p = 7 mod 8 and roughly 20 digits).
Cado runs without issues but the computed values seem inconsistent.
Here's an example (generated with PARI/GP):
p = 262086107969265031
ell = 32760763496158129 #(largest prime factor of p^2 - 1)
c = ffgen([p,2])
g=216232938003097459*c + 190041067314658365
x=117385794987197527*c + 235757958534339998
h=11818731183008556
We can check that g is generating the subgroup of order ell in GF(p^2) with fforder(g) and g^h = x.
Now I want to compute h with Cado-nfs using the following commands:
cado-nfs/cado-nfs.py 262086107969265031 -dlp -ell 32760763496158129 -gfpext 2 --workdir=/data/cado-nfs/test
-> Runs and builds the logs of the factor base elements without issue.
cado-nfs/cado-nfs.py /data/cado-nfs/test/p2dd20.parameters_snapshot.0 target=216232938003097459,190041067314658365
-> Info:root: target = 216232938003097459,190041067314658365
Info:root: log(target) = 13394876329845831
cado-nfs/cado-nfs.py /data/cado-nfs/test/p2dd20.parameters_snapshot.1 target=117385794987197527,235757958534339998
-> Info:root: target = 117385794987197527,235757958534339998
Info:root: log(target) = 30091716292081506
Now back to PARI/GP: h_cado = Mod(30091716292081506,ell)/Mod(13394876329845831,ell)
g^h_cado isn't equal to x as h_cado != h
What went wrong here ? Is my formatting of the target parameter correct (undocumented, I tried to guess by looking at scripts/descent.py) ? I tried several other examples with different primes but I never seem to get the correct answer.
I run the latest git master pulled a few days ago and can provide log files and factor bases if needed.
Unrelated to this example, I also tried to compute the dlp for the same pair of targets (and same field GF(p^2)) on two different factor bases by running the computations twice in two different workdirs, and the resulting h_cado after rebasing the log(target) to g were different. Is that to be expected ?
Best regards,
Filip
- [Cado-nfs-discuss] DLP computations in GF(p^2), Filip Fifka, 04/15/2020
- Re: [Cado-nfs-discuss] DLP computations in GF(p^2), Aurore Guillevic, 04/15/2020
- Re: [Cado-nfs-discuss] DLP computations in GF(p^2), Filip Fifka, 04/16/2020
- Re: [Cado-nfs-discuss] DLP computations in GF(p^2), Pierrick Gaudry, 04/16/2020
- Re: [Cado-nfs-discuss] DLP computations in GF(p^2), Filip Fifka, 04/17/2020
- Re: [Cado-nfs-discuss] DLP computations in GF(p^2), Pierrick Gaudry, 04/17/2020
