- To: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Computation on multi-socket server
- Date: Thu, 16 Apr 2020 16:49:31 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=valentin@wans-janser.de; spf=None smtp.mailfrom=valentin@wans-janser.de; spf=Pass smtp.helo=postmaster@smtprelay05.ispgateway.de
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Paul,
Am 16.04.2020 um 15:38 schrieb paul zimmermann:
> Dear Valentin,
> it appears from looking at your console logs that singlecpuserver.out.txt
> is using cado-nfs 2.3.0, while dualcpuserver.out.txt is using the
> development
> version.
now that you say it, it comes to my mind.
I didn't think there was any big difference between these versions which
is why I did not pay a lot of attention to it...
> It might well be there is some inefficiency in the development version.
You are totally right.
> Please can you try on your dual-core server with 2.3.0?
I factored the same, 100-digit RSA number again (on the
dual-cpu-server), this time I got a cpu time of 11127 seconds and a wall
clock time of 533 seconds!
I think that's a great time to achieve, no application can scale 100 %
efficiently with an increasing number of cores/cpus.
> Best regards,
> Paul
Thank you for your time, stay safe and keep up the great work!
Best regards,
Valentin
- [Cado-nfs-discuss] Computation on multi-socket server, Valentin Janser, 04/15/2020
- Re: [Cado-nfs-discuss] Computation on multi-socket server, paul zimmermann, 04/15/2020
- Re: [Cado-nfs-discuss] Computation on multi-socket server, Valentin Janser, 04/15/2020
- Re: [Cado-nfs-discuss] Computation on multi-socket server, paul zimmermann, 04/16/2020
- Re: [Cado-nfs-discuss] Computation on multi-socket server, Valentin Janser, 04/16/2020
