- To: Paul Zimmermann <Paul.Zimmermann@inria.fr>
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Infinite loop in sqrt
- Date: Tue, 4 Aug 2020 19:31:02 +0200 (CEST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=eric.jeancolas@free.fr; spf=None smtp.mailfrom=eric.jeancolas@free.fr; spf=None smtp.helo=postmaster@smtp3-g21.free.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Paul,
Very good idea! It will more friendly that having the feeling to have reached
a roundabout with a no-way sign at each exit!
About the sqside option, yes I did. Indeed, I put tasks.sieve.sqside = 0 in
the parameter file I use for SNFS. With the spaces around the "=" in the
parameter file.
Best regards.
----- Mail original -----
De: "Paul Zimmermann" <Paul.Zimmermann@inria.fr>
À: "eric jeancolas" <eric.jeancolas@free.fr>
Cc: "Emmanuel Thome" <Emmanuel.Thome@inria.fr>,
Envoyé: Mardi 4 Août 2020 16:34:05
Objet: Re: [Cado-nfs-discuss] Infinite loop in sqrt
Dear Eric,
> Date: Mon, 3 Aug 2020 18:26:05 +0200 (CEST)
> From: eric.jeancolas@free.fr
> Ah ok, as you mentionned, I thought this situation was rare enough not to
> encounter it!
> As the deg 6 polynomial gave me the result, I will not proceed on this case.
> At least, I've got the answer, and it is shared on the group.
> Thank you for that.
> Best regards.
> Eric
to avoid such infinite loops in the future, I've added an error message
when we find no suitable prime < 1000000. In such a case the error message
points to the README, paragraph "Factoring with SNFS".
Best regards,
Paul
PS: by the way, did you use tasks.sieve.sqside=0 with your SNFS polynomials?
- [Cado-nfs-discuss] Infinite loop in sqrt, eric . jeancolas, 08/03/2020
- Re: [Cado-nfs-discuss] Infinite loop in sqrt, Emmanuel . Thome, 08/03/2020
- Re: [Cado-nfs-discuss] Infinite loop in sqrt, eric . jeancolas, 08/03/2020
- Re: [Cado-nfs-discuss] Infinite loop in sqrt, Paul Zimmermann, 08/04/2020
- Re: [Cado-nfs-discuss] Infinite loop in sqrt, eric . jeancolas, 08/04/2020
