- To: Paul Zimmermann <Paul.Zimmermann@inria.fr>
- Cc: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
- Subject: Re: [Cado-nfs-discuss] Cado-nfs-discuss Digest, Vol 98, Issue 4
- Date: Tue, 15 Sep 2020 13:40:53 +0000 (UTC)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=ed_ka2fwj@yahoo.com; spf=Pass smtp.mailfrom=ed_ka2fwj@yahoo.com; spf=None smtp.helo=postmaster@sonic305-2.consmr.mail.bf2.yahoo.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Paul,
For the current (Aug 2020 commit) run, I believe they are all the same commit, but I have about 40 clients. Am I going to need to take all of them back to May? If so, is there an easy way to do that and then bring them back to current? Or, am I going to have to recompile in both directions? I'm thinking of copying the directory as a possibility. Is there an easier way?
The first result should be available in an hour or so, but if I need to recompile all my clients, that may take a bit longer to make my next run.(smile)
Thanks,
Ed
On Tuesday, September 15, 2020, 8:24:56 AM EDT, Paul Zimmermann <paul.zimmermann@inria.fr> wrote:
Dear Ed,
> My plan at this point, then, is to rerun the first c130 (earlier commit), but
> with the August 2020 commit, followed by the same c130 with the May21st
> commit. Does that sound like it will meet the needs? Will the clients need
> to be old or new for the May commit?
yes this would be great. Please use the same revision for the server and
clients, otherwise it will be more difficult to isolate the issue.
What we need is the content of the c130.log file (which contains the history
of all filtering attempts) and the content of the c130.dup2* files, and that
for each commit you try.
Paul
Paul
- Re: [Cado-nfs-discuss] Cado-nfs-discuss Digest, Vol 98, Issue 4, Ed Hall, 09/15/2020
- Re: [Cado-nfs-discuss] Cado-nfs-discuss Digest, Vol 98, Issue 4, Paul Zimmermann, 09/15/2020
