- To: Paul Zimmermann <Paul.Zimmermann@inria.fr>
- Cc: "cado-nfs-discuss@lists.gforge.inria.fr" <cado-nfs-discuss@lists.gforge.inria.fr>
- Subject: Re: [Cado-nfs-discuss] Newer Commit Takes Longer to filter (Ed Hall)
- Date: Wed, 16 Sep 2020 16:29:59 +0000 (UTC)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=ed_ka2fwj@yahoo.com; spf=Pass smtp.mailfrom=ed_ka2fwj@yahoo.com; spf=None smtp.helo=postmaster@sonic316-11.consmr.mail.bf2.yahoo.com
- Ironport-phdr: 9a23:Gf9BQxVvmKuchG0MeDZFhQiPYS7V8LGtZVwlr6E/grcLSJyIuqrYZRSGtadThVPEFb/W9+hDw7KP9fy5BipYu93Q7DhCKMUKC0Zbz51O3kQJO42sMQXDNvnkbig3ToxpdWRO2DWFC3VTA9v0fFbIo3e/vnY4ExT7MhdpdKyuQtaBx8u42Pqv9JLNfg5GmCSyYa9oLBWxsA7dqtQajZFtJ6osyBbFuGdEd/pZyW5sKl+YghLw6tut8JJ5/ClcpvMs+9RcXanmeqgzUKBVAikhP20p/sPgqAPNTRGI5nsSU2UWlgRHDg3Y5xzkXZn/rzX3uPNl1CaVIcP5Q7Y0WS+/76hwUx/nlD0HNz8i/27JjMF7kb9Wrwigpxx7xI7UfZ2VOf9jda7TYd8WWWxMVdtKWidfHo2zcZcAD+sZPeZZsYb9oUcOrQCjDgWoHe/j1yNEimPz0aA8zu8vExzJ3BY4EtwAsHrastb7O6UcUe6ow6bH0TLNYuhM1jvh84fHaQosre2OUL92bMHfyVMvFwTAjliIpoLqIi6e2OYXvGif6+prSOWihHA6pA5poTig3NkgiofHh4IX0V3F9T92wIYyJd2/UkJ0fdmkEJ5JuiycKoB5Td8sTXtytyYm1r0Jp4S7fC4SxZopxBPSdeCKfouU7x/+UOudPzl1iG94dL+8iRu+7EutxOLzW8SqzFtHripIn9nMuH0O2BLe6smKR/ly8Eq91ziC0R3Y5O9DIUAxj6XbKpghz6Y1lpUNq0TDBTH5mEPwjKCIeEUk/fKo6/niYrn8vJOcMJV0ig7mPqQrhMO/G/84PRYIX2id5+u82rrj/VfkQLVPlPE2lbPZsJ/cKM8GpaC5GxdY34Qs5hqlDjqqyskUkHcbIF5fZR6LkZXlNlfTK/7iF/i/mU6jkDJzyvDGILLhBpLNI2DYkLfme7Z96lJTxQQuwd1e/p5YF6wNLOjvVU/2stzYFRo5Mxauz+biEtp914ceVXiUDa+XLq/eq1+J6fgvI+mLY48ZoiryK/8g5/L2jH85n0ESfbWx0JYVZ320BPVrL1+EbXfintsNC3oGshQjQODyjV2NSz9TZ3K8X6Im4TE7DZqrApneSY+1g7yOxjm3HpNYZ2BEEV2NEW3nd4WDW/cLci6dPshhkjkcWbi7V4AhzQ2utBP9y7d/MuXb4DAXtZX62Nhz6e3Tjgg++iF1D8SGz26NUnp0nngTSj8y3aB/ulB9ykyZ3ah3jfxYEsZT5/xXXQsgNJ7cyfZ6C9HoVQ7bcNeJUgXuftLzOTgsSpoDwtoLblx4EtOkxkT71jeuRY0UkrmGHpk99KT03n7rJs87xWyQh4c7iFxzb8cHFWSiguYr+gTkBIeTnVqbv7ejdaMbmiXK8THQniK1oEhEXVsoAu3+VncFax6T9Iyhvx6Qf/qVEb0idzB554uCJ69NMYy7llJARfy4YYqbOjv3kGC2HhOSgLaFbY6scWtHmjTUCE8D1QsU+CTebFRsNmKau2vbSQdWOxf3eUq1qLtvoXO8SQk/yATYNxQwhYrwwQYcgLmnc91W27sFvCk7rDAtRQSs1tLRDJyLoA8zJag=
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Dear Paul,
Here is the link for the c130 run with earlier (Sep 2019) commit*: https://www.mersenneforum.org/attachment.php?attachmentid=23339&d=1600273382
*This commit is for the server only. If I need to change all the clients to this commit, it will take a bit of time, and IIRC, some of the clients wouldn't compile this commit (but it could have been a close commit that I had troubles with).
Thanks for all the help.
Sincerely,
Ed
On Wednesday, September 16, 2020, 10:31:53 AM EDT, Paul Zimmermann <paul.zimmermann@inria.fr> wrote:
Ed,
> I did revert all my farm to the May commit for the recent tests. Let me know
> if you still want me to revert them to an earlier commit and whether I should
> revert the entire farm, or go with the original mix and match farm that
> produced the shorter times for the earlier c130. OR, if you would rather I
> run something in the c15x region on the already set up May commit, I could
> easily do that.
as I said earlier, what would be most useful at this point would be to have
the same tarball for the c130, but for the 2019 commit you used.
(Comparing with a different number will make it more difficult to isolate the
issue.)
Paul
> easily do that.
issue.)
Paul
- Re: [Cado-nfs-discuss] Newer Commit Takes Longer to filter (Ed Hall), Ed Hall, 09/16/2020
- Re: [Cado-nfs-discuss] Newer Commit Takes Longer to filter (Ed Hall), Paul Zimmermann, 09/16/2020
- <Possible follow-up(s)>
- [Cado-nfs-discuss] Newer Commit Takes Longer to filter (Ed Hall), Paul Zimmermann, 09/21/2020
