cado-nfs - [Cado-nfs-discuss] Problem in cado-nfs-client.py in cado-nfs-3.0.0 dev
  • To: cado-nfs-discuss@lists.gforge.inria.fr
  • Subject: [Cado-nfs-discuss] Problem in cado-nfs-client.py in cado-nfs-3.0.0 dev
  • Date: Fri, 23 Oct 2020 18:14:07 +0200 (CEST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=eric.jeancolas@free.fr; spf=None smtp.mailfrom=eric.jeancolas@free.fr; spf=None smtp.helo=postmaster@smtp6-g21.free.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
  • List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Hello
When I use cado-nfs-client.py from the 2.3.0 version and use a 3.0.0 server,
with the simplest way (no ssl), it works fine, even if the userid client is
not the same as the userid server.
When I use cado-nfs-client.py from the 3.0.0-dev version (well, I downloaded
it about one year ago) with a 3.0.0 server, same userid, no problem.
But when I use cado-nfs-client.py from the 3.0.0-dev version with a server
and a different id, there is a file not found condition.
I don't understand what has changed between 2.3.0 and 3.0.0. Maybe there are
new options.
Could you please help me?
Here is the sysout when it doesn't work.
./cado-nfs-client.py --server=http://10.100.1.91:36601
INFO:root:Starting client acces-ThinkCentre-Edge72-1.9ed30a6e
INFO:root:Python version is 2.7.18
INFO:root:spin=0 is_wu=True blog=0
INFO:root:Downloading
http://10.100.1.91:36601/cgi-bin/getwu?clientid=acces-ThinkCentre-Edge72-1.9ed30a6e
to download/WU.acces-ThinkCentre-Edge72-1.9ed30a6e521948531 (cafile = None)
INFO:root:spin=0 is_wu=False blog=0
INFO:root:Downloading http://10.100.1.91:36601/77727_196.poly to
download/77727_196.poly528467685 (cafile = None)
INFO:root:Downloading http://10.100.1.91:36601/77727_196.roots1.gz to
download/77727_196.roots1.gz949229450 (cafile = None)
ERROR:root:Existing file download/las has wrong checksum
ef6017f621a72888b3159360cf2816baef9e9003, workunit specified
f071c486c06ef61dabcd248aca2fb9e4064450f1. Deleting file.
INFO:root:Downloading http://10.100.1.91:36601/las to download/las1037306668
(cafile = None)
INFO:root:Setting executable flag for download/las
INFO:root:Result file
acces-ThinkCentre-Edge72-1.9ed30a6e.work/77727_196.93740000-93760000.gz does
not exist
INFO:root:Running 'download/las' -I 12 -poly 'download/77727_196.poly' -q0
93740000 -q1 93760000 -lim0 13400000 -lim1 13400000 -lpb0 28 -lpb1 28 -mfb0
55 -mfb1 55 -lambda0 2.5 -lambda1 2.5 -fb1 'download/77727_196.roots1.gz'
-out
'acces-ThinkCentre-Edge72-1.9ed30a6e.work/77727_196.93740000-93760000.gz' -t
2 -sqside 0 -stats-stderr
Traceback (most recent call last):
File "./cado-nfs-client.py", line 2308, in <module>
client_ok = client.process()
File "./cado-nfs-client.py", line 2054, in process
processor.run_commands()
File "./cado-nfs-client.py", line 1287, in run_commands
preexec_fn=renice_func)
File "./cado-nfs-client.py", line 610, in run_command
**kwargs)
File "/usr/lib/python2.7/subprocess.py", line 394, in __init__
errread, errwrite)
File "/usr/lib/python2.7/subprocess.py", line 1047, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
