- To: eric.jeancolas@free.fr
- Cc: cado-nfs-discuss@lists.gforge.inria.fr
- Subject: Re: [Cado-nfs-discuss] Problem in cado-nfs-client.py in cado-nfs-3.0.0 dev
- Date: Fri, 23 Oct 2020 18:53:58 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/cado-nfs-discuss/>
- List-id: A discussion list for Cado-NFS <cado-nfs-discuss.lists.gforge.inria.fr>
Many things have changed between 2.3.0 and 3.0.0-dev. Mixing and
matching clients and servers from different versions has never been a
goal (which I accept blame for. Presumably I could work to alleviate this
a little bit, but since we're not sending versions numbers in the
communication stream, there is probably not much that can be done).
The user id should not matter.
"3.0.0-dev from one year ago" is not a thing, sorry. There might be
something fishy going on, but could you please try with a more recent
version ? (ideally with python3 for the client, since we've deprecated
python2 now)
out of curiosity, what is your filesystem ?
E.
On Fri, Oct 23, 2020 at 06:14:07PM +0200, eric.jeancolas@free.fr wrote:
> Hello
> When I use cado-nfs-client.py from the 2.3.0 version and use a 3.0.0
> server, with the simplest way (no ssl), it works fine, even if the userid
> client is not the same as the userid server.
> When I use cado-nfs-client.py from the 3.0.0-dev version (well, I
> downloaded it about one year ago) with a 3.0.0 server, same userid, no
> problem.
> But when I use cado-nfs-client.py from the 3.0.0-dev version with a server
> and a different id, there is a file not found condition.
> I don't understand what has changed between 2.3.0 and 3.0.0. Maybe there
> are new options.
> Could you please help me?
> Here is the sysout when it doesn't work.
> ./cado-nfs-client.py --server=http://10.100.1.91:36601
> INFO:root:Starting client acces-ThinkCentre-Edge72-1.9ed30a6e
> INFO:root:Python version is 2.7.18
> INFO:root:spin=0 is_wu=True blog=0
> INFO:root:Downloading
> http://10.100.1.91:36601/cgi-bin/getwu?clientid=acces-ThinkCentre-Edge72-1.9ed30a6e
> to download/WU.acces-ThinkCentre-Edge72-1.9ed30a6e521948531 (cafile = None)
> INFO:root:spin=0 is_wu=False blog=0
> INFO:root:Downloading http://10.100.1.91:36601/77727_196.poly to
> download/77727_196.poly528467685 (cafile = None)
> INFO:root:Downloading http://10.100.1.91:36601/77727_196.roots1.gz to
> download/77727_196.roots1.gz949229450 (cafile = None)
> ERROR:root:Existing file download/las has wrong checksum
> ef6017f621a72888b3159360cf2816baef9e9003, workunit specified
> f071c486c06ef61dabcd248aca2fb9e4064450f1. Deleting file.
> INFO:root:Downloading http://10.100.1.91:36601/las to
> download/las1037306668 (cafile = None)
> INFO:root:Setting executable flag for download/las
> INFO:root:Result file
> acces-ThinkCentre-Edge72-1.9ed30a6e.work/77727_196.93740000-93760000.gz
> does not exist
> INFO:root:Running 'download/las' -I 12 -poly 'download/77727_196.poly' -q0
> 93740000 -q1 93760000 -lim0 13400000 -lim1 13400000 -lpb0 28 -lpb1 28 -mfb0
> 55 -mfb1 55 -lambda0 2.5 -lambda1 2.5 -fb1 'download/77727_196.roots1.gz'
> -out
> 'acces-ThinkCentre-Edge72-1.9ed30a6e.work/77727_196.93740000-93760000.gz'
> -t 2 -sqside 0 -stats-stderr
> Traceback (most recent call last):
> File "./cado-nfs-client.py", line 2308, in <module>
> client_ok = client.process()
> File "./cado-nfs-client.py", line 2054, in process
> processor.run_commands()
> File "./cado-nfs-client.py", line 1287, in run_commands
> preexec_fn=renice_func)
> File "./cado-nfs-client.py", line 610, in run_command
> **kwargs)
> File "/usr/lib/python2.7/subprocess.py", line 394, in __init__
> errread, errwrite)
> File "/usr/lib/python2.7/subprocess.py", line 1047, in _execute_child
> raise child_exception
> OSError: [Errno 2] No such file or directory
> _______________________________________________
> Cado-nfs-discuss mailing list
> Cado-nfs-discuss@lists.gforge.inria.fr
> https://lists.gforge.inria.fr/mailman/listinfo/cado-nfs-discuss
- [Cado-nfs-discuss] Problem in cado-nfs-client.py in cado-nfs-3.0.0 dev, eric . jeancolas, 10/23/2020
- Re: [Cado-nfs-discuss] Problem in cado-nfs-client.py in cado-nfs-3.0.0 dev, Emmanuel Thomé, 10/23/2020
