- To: cado-nfs@inria.fr
- Subject: [cado-nfs] sqrt error
- Date: Mon, 26 Apr 2021 07:24:08 +0200 (CEST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=eric.jeancolas@free.fr; spf=Pass smtp.mailfrom=eric.jeancolas@free.fr; spf=None smtp.helo=postmaster@smtp2-g21.free.fr
- Ironport-hdrordr: A9a23:xfdUHqjepPPI8u/OfmkCZrDpgnBQXnYji2hD6mlwRA09T+WzkceykPMHkSLugDEKV3063fyGMq+MQXTTnKQFhLU5F7GkQQXgpS+UPJhvhLGSoQHINg/f0qpm1alme7VjE9GYNzJHpOvz/QXQKbsd6fad9qTAv4vj5ldrCTpncqRxqzp+Yzz7LmRTZC1rQaU0D4Cd4M0vnUvCRV0yYt6gDncIG8jvzuekqLvcbRQLBwEq5WC15FvC1JfBDxOa0h0COgku/Z4e9wH+/DDR1+GKr+y7xhjA12Xa8pha3Of6xsArPr3rtuElbhHligOlf+1aKtq/lQFwhvqu5lYsmMTNpBllH/0b0QK0Ql2I
- Ironport-phdr: A9a23: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
Hello
I got the following error in the last step of a process:
Error:Square Root: Error, N does not divide resultant of given polynomials,
or there are multiplicities.
Error:Square Root: Can not compute m.
I'm in a snfs mode.
The polynomial is as follows:
n:
181570647363941951922859674104963771103015312977807439204421953197794821673476296854978179746096739603508598016332617111965534228905323443567644055007324027034168949
skew: 1.36
type: snfs
c0: -80
c5: 17
Y0: 100000000000000000000000000000000
Y1: -1
Which parameter can I tune to prevent this error?
If such a parameter is easy to tune, could you add a line on the Error
message to give such an advice? With something like:
Error:Square Root: This is due to blah blah, try a larger tasks.blah.blah
parameter...
Best regards.
Éric
- [cado-nfs] sqrt error, eric . jeancolas, 04/26/2021
- Re: [cado-nfs] sqrt error, Pierrick Gaudry, 04/26/2021
- Re: [cado-nfs] sqrt error, eric . jeancolas, 04/26/2021
- Re: [cado-nfs] sqrt error, Paul Zimmermann, 04/26/2021
- Re: [cado-nfs] sqrt error, eric . jeancolas, 04/27/2021
- Re: [cado-nfs] sqrt error, Paul Zimmermann, 04/27/2021
- Re: [cado-nfs] sqrt error, Emmanuel Thomé, 04/27/2021
