- To: Paul Zimmermann <Paul.Zimmermann@inria.fr>
- Cc: pierrick gaudry <pierrick.gaudry@loria.fr>, cado-nfs@inria.fr
- Subject: Re: [cado-nfs] sqrt error
- Date: Tue, 27 Apr 2021 06:41:36 +0200 (CEST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=eric.jeancolas@free.fr; spf=Pass smtp.mailfrom=eric.jeancolas@free.fr; spf=None smtp.helo=postmaster@smtp2-g21.free.fr
- Ironport-hdrordr: A9a23:xYEswqkUOa4qxBysdmAKo84x7tDpDfKI3DAbvn1ZSRFFG/GwvcrGppom/DXzjyscX2xlpMuJP7OOTWiZ2Zl+54QQOrnKZniDhEKDKoZ+4Yz+hwDxAiGWzJ856Y5MUYhbTOfxA19zkNrg7GCDeeoI7dGb/MmT6Nv24GxqSWhRB51IzwA8MQqDF10zeQ8uP/oEPb69wuYCmDa6Y3QQaa2Adxs4dszOvcfCmp6jQTNuPX8awTKDhz+p97L2eiLwtnwjeglSyrQv+3WtqX2b2oyftZiApSP05iv684lWlNz9ytFKGcCAzvQOJi6EsHfQWK1RH5mLvDU4u4iUmTAXueiJhQwhMcR1427QeW/wgSKF4XiG7AoT
- Ironport-phdr: A9a23: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
Dear Paul
I explain here what I did to test, to be sure I did what you expect.
I downloaded a new version of cado-nfs from
https://gitlab.inria.fr/cado-nfs/cado-nfs/-/commits/7694b91283f11131ec54fe19c7d3ff8cdf8b97ad/
On my conputer, I erased previous cado directories, and I made a tar on
cado-nfs-7694b91283f11131ec54fe19c7d3ff8cdf8b97ad.tar.gz and a make.
I issued the following command: ./cado-nfs.py
181570647363941951922859674104963771103015312977807439204421953197794821673476296854978179746096739603508598016332617111965534228905323443567644055007324027034168949
tasks.polyselect.import=18888_164.poly
The contents of 18888_164.poly is:
n:
skew: 1.36
type: snfs
c0: -80
c5: 17
Y0: 1000000000000000000000000000000000
Y1: -1
# f(x) = 17*x^5-80
# g(x) = -x+1000000000000000000000000000000000
I reached the following steps:
Info:Generate Factor Base: Starting
Info:Generate Factor Base: Finished
Info:Generate Factor Base: Total cpu/real time for makefb: 22.1/19.6028
Info:Generate Free Relations: Starting
Info:Generate Free Relations: Found 1410662 free relations
Info:Generate Free Relations: Finished
Info:Generate Free Relations: Total cpu/real time for freerel: 462.44/319.124
Info:Lattice Sieving: Starting
Info:Lattice Sieving: We want 63458945 relation(s)
Info:Lattice Sieving: Adding workunit c165_sieving_30592187-30595000 to
database
Info:Lattice Sieving: Adding workunit c165_sieving_30595000-30600000 to
database
When I have a mismatch on a number, I don't reach Lattice Sieving.
So I stopped the process (Ctrl+C) just after that.
Just to recall here: the number
has been erroneously generated after some star removals.
The number to be factorized is 18888_164 = (17*10^164-8)/9 =
(17*(10^33)^5-80)/90 =
181*5706473639419519*22859674104963771103015312977807439204421953197794821673476296854978179746096739603508598016332617111965534228905323443567644055007324027034168949
( and eventually =
181*5706473639419519*7159052365561448148227529365476870909708139900919265573*3193114526571981969989829734950032818678374603944682479503444963111309977900602192542410513
The snfs polynomial has been generated accordingly.
Can you reproduce the problem, or is it related to my installation?
Best regards.
Eric
----- Mail original -----
De: "Paul Zimmermann" <Paul.Zimmermann@inria.fr>
À: "eric jeancolas" <eric.jeancolas@free.fr>
Cc: "pierrick gaudry" <pierrick.gaudry@loria.fr>, cado-nfs@inria.fr
Envoyé: Lundi 26 Avril 2021 14:51:07
Objet: Re: [cado-nfs] sqrt error
Dear Eric,
are you sure you used the exact revision I mention below (git co 7694b91)?
I had to revert my commit later since it broke some tests.
Paul
> Date: Mon, 26 Apr 2021 13:18:12 +0200 (CEST)
> From: eric.jeancolas@free.fr
> Dear Paul,
> I reinstalled cado and fiel timestamps are 26/04/2021 11:19.
> The problem is still the same, the number is not viewed as an error before
> sieving is starting.
> Best regards.
> Eric
> Envoyé: Lundi 26 Avril 2021 09:04:19
> Dear Eric,
> please try the latest commit (7694b91) and please confirm it gives an error
> during the first check process.
> Best regards,
> Paul
- [cado-nfs] sqrt error, eric . jeancolas, 04/26/2021
- Re: [cado-nfs] sqrt error, Pierrick Gaudry, 04/26/2021
- Re: [cado-nfs] sqrt error, eric . jeancolas, 04/26/2021
- Re: [cado-nfs] sqrt error, Paul Zimmermann, 04/26/2021
- Re: [cado-nfs] sqrt error, eric . jeancolas, 04/27/2021
- Re: [cado-nfs] sqrt error, Paul Zimmermann, 04/27/2021
- Re: [cado-nfs] sqrt error, Emmanuel Thomé, 04/27/2021
