- To: cado-nfs@inria.fr
- Subject: [cado-nfs] Higher ropteffort can produce worse polynomial
- Date: Mon, 13 Dec 2021 20:47:45 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=rhb11931@gmail.com; spf=Pass smtp.mailfrom=rhb11931@gmail.com; spf=None smtp.helo=postmaster@mail-yb1-f174.google.com
- Ironport-data: A9a23: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
- Ironport-hdrordr: A9a23:RM6Mq6EhuSSgfYu5pLqE5ceALOsnbusQ8zAXPiFKOHtom6mj/fxG885rtiMc5AxwZJhCo7G90cu7MBHhHPdOiOF7AV7IZniChILHFvAH0WIg+VHd8u/Fm9K1GZ0OT0G2MrPNMWQ=
- Ironport-phdr: A9a23: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
Dear all,
Mersenneforum user Gimarel has reported that using a higher ropteffort value can sometimes produce a lower scoring polynomial.
For example, if polyselect_ropt is run on the attached polynomial, with -area 429496729600000000 -Bf 34359738368 -Bg 17179869184, the Murphy-E score of the resulting polynomial is as follows:
-ropteffort 1: 2.026e-09
-ropteffort 10: 1.972e-09
-ropteffort 100: 1.965e-09
Maybe this is just an unlucky consequence of the way the priority queues are managed, but I'm concerned that perhaps at some stage a queue is either being cut too short or not being sorted properly.
I note that when polyselect_ropt is run with -v, the following is printed:
# Info: s1param->nbest_sl: 368 (= size_total_sublattices*ropteffort)
...and despite what this would suggest, the value 368 does not change when ropteffort is increased!
Best regards,
Robert
2_2246M_gimarel.poly
Description: Binary data
- [cado-nfs] Higher ropteffort can produce worse polynomial, Robert Balfour, 12/13/2021
- Re: [cado-nfs] Higher ropteffort can produce worse polynomial, Paul Zimmermann, 12/14/2021
- Re: [cado-nfs] Higher ropteffort can produce worse polynomial, Shi Bai, 12/20/2021
