- To: Robert Balfour <rhb11931@gmail.com>
- Cc: cado-nfs@inria.fr
- Subject: Re: [cado-nfs] Higher ropteffort can produce worse polynomial
- Date: Tue, 14 Dec 2021 13:38:34 +0100
- Ironport-data: A9a23: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
- Ironport-hdrordr: A9a23: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
thank you Robert for the report. We will track this issue at
https://gitlab.inria.fr/cado-nfs/cado-nfs/-/issues/30026.
Paul
> From: Robert Balfour <rhb11931@gmail.com>
> Date: Mon, 13 Dec 2021 20:47:45 +0000
> [1:multipart/alternative Hide]
> [1/1:text/plain Show]
> [1/2:text/html Hide Save:noname (3kB)]
> Dear all,
> Mersenneforum user Gimarel has reported that using a higher ropteffort value
> can sometimes produce a lower scoring polynomial.
> For example, if polyselect_ropt is run on the attached polynomial, with
> -area 429496729600000000 -Bf 34359738368 -Bg 17179869184, the Murphy-E score
> of the resulting polynomial is as follows:
> -ropteffort 1: 2.026e-09
> -ropteffort 10: 1.972e-09
> -ropteffort 100: 1.965e-09
> Maybe this is just an unlucky consequence of the way the priority queues are
> managed, but I'm concerned that perhaps at some stage a queue is either
> being cut too short or not being sorted properly.
> I note that when polyselect_ropt is run with -v, the following is printed:
> # Info: s1param->nbest_sl: 368 (= size_total_sublattices*ropteffort)
> ...and despite what this would suggest, the value 368 does not change when
> ropteffort is increased!
> Best regards,
> Robert
> [2:application/octet-stream Show Save:2_2246M_gimarel.poly (601B)]
- [cado-nfs] Higher ropteffort can produce worse polynomial, Robert Balfour, 12/13/2021
- Re: [cado-nfs] Higher ropteffort can produce worse polynomial, Paul Zimmermann, 12/14/2021
- Re: [cado-nfs] Higher ropteffort can produce worse polynomial, Shi Bai, 12/20/2021
