- To: "cado-nfs@inria.fr" <cado-nfs@inria.fr>
- Subject: [cado-nfs] Discussion related to cado-nfs
- Date: Wed, 22 Dec 2021 03:25:59 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=factorn@pm.me; spf=Pass smtp.mailfrom=factorn@pm.me; spf=Pass smtp.helo=postmaster@mail-4316.protonmail.ch
- Ironport-data: A9a23:ApekUq56xl3yVYTRsyFJIwxRtGbGchMFZxGqfqrLsXjdYENS32MOzTdOWDjVbPbZazOkKdt2aoSy/R8B7JXQzdQ1TlAd+CA2RRqmi+KVXIXDdh+Y0wC6d5CYEho/t63yUjRxRSwNZie0SiyFb/6x/RGQ6YnSHuClUbSeY3gqLeNZYH5JZSxLy7ZRbrFA2oDR7zOl4bsekuWHULOX82Yc3lE8t8pvnChSUMHa41v0iLCRicdj5zcyn1FNZH4WyDrYw3HQGuG4FcbiLwrPIS3Qw4/Xw/stIovNfrfTd0QLRvuOZlHQzGJMXLSlhB1Lpyh02aZT2Pg0MBcKzWrR2YwqjowT3XCzYV9B0qnklu0WTx5CFQlmOOtD9dcrJFDm65XNlBeYIxMAxN01VBBrbN1IkgptOklF/PAfbTYDdTiYlueuyfS6TPNtj4ItNqHW0Ck3rik1lneEGa9zGdabV/+fvZkCgWlukpsbRbCDc5VMQCRJRxHmTx1rG14xNIgYiL7w0yG7KCkwREm9oKM25y2Pl1UvlqD3N8bSfNmDRMETlUbwm44PxEyhajlyCTBV4WPtHrOQau7zcefTXYsTEPjkrac0xkWJwXAUDhgfVF/9qvnRZouWRYdEM0JNksYxhfFayaBpZoCVs96ETLqsphtaXtc4/ygS9lSW0qSNi+qGLjFsc9OCAeDKcOcuQHov2zdlWvuB6SNH6NWodJ5WyltYQf5e98TYwa/uqBLolTc43uQ=
- Ironport-hdrordr: A9a23:7+2g+Kx0x6nXhB+766ZxKrPwWb1zdoMgy1knxilNoHNuHvBw+/rCoB1k73HJYV8qMRlKpTnqAsa9qB3nn6JI3Q==
- Ironport-phdr: A9a23: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
Hello,
I compiled from master branch ( commit: d7ccce67fbf4 ). Build success on Ubuntu 20.04. There are some numbers that give an error, upon closer look the error message is:
/Git/cado-nfs$ time ./cado-nfs.py 108725311124863713831801731901593Traceback (most recent call last):File "./cado-nfs.py", line 144, in <module>parameters, db = toplevel_params.get_cooked_parameters()File "/Git/cado-nfs/./scripts/cadofactor/toplevel.py", line 1175, in get_cooked_parametersself.set_N_paramfile_workdir()File "/Git/cado-nfs/./scripts/cadofactor/toplevel.py", line 647, in set_N_paramfile_workdirself.args.parameters = self.find_default_parameter_file()File "/Git/cado-nfs/./scripts/cadofactor/toplevel.py", line 186, in find_default_parameter_fileraise RuntimeError("no parameter file found"RuntimeError: no parameter file found for c33 (tried c33, c35)
Same message on trying to factor 151132207742640142005548601981029.
Incidentally, I cannot get Tag 2.3.0 to compile on my system running Ubuntu 20.04. I am compiling with gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, so many errors.
Has anyone actually tried to compile that version with a modern Compiler on a recent OS? I saw documentation using GCC 4.7.2, see https://cado-nfs.gitlabpages.inria.fr/.
Surely the latest compilers will have a drastic difference in performance.
Thank you.
-N
- [cado-nfs] Discussion related to cado-nfs, N, 12/22/2021
- Re: [cado-nfs] Discussion related to cado-nfs, Paul Zimmermann, 12/22/2021
- Re: [cado-nfs] Discussion related to cado-nfs, Pierrick Gaudry, 12/22/2021
- Re: [cado-nfs] Discussion related to cado-nfs, N, 12/22/2021
