cado-nfs - Re: [cado-nfs] Inquiry about solving DLP on ARM processor and 386-bit DLP on intel processor
  • To: 酒見由美 <yumi.sakemi@gmo-cybersecurity.com>
  • Cc: cado-nfs@inria.fr
  • Subject: Re: [cado-nfs] Inquiry about solving DLP on ARM processor and 386-bit DLP on intel processor
  • Date: Tue, 05 Jul 2022 07:54:28 +0200
  • Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@tomate
Dear Yumi,
in the first case (error_log_solving_DLP_on_arm.txt) I see in the log file:
Error:Linear Algebra: Unsupported combination: group size =
1, p =
37858785688058251908976098251106649423874744726099768156267414181577309352921,
4 limbs
It seems you are trying to run the generic mpfq code (pz) whereas your number
has only 4 limbs, thus you should use COMPILE_MPFQ_PRIME_FIELD_p_4.
Best regards,
Paul
