Re: [cado-nfs] Inquiry about solving DLP on ARM processor and 386-bit DLP on intel processor
- To: 酒見由美 <yumi.sakemi@gmo-cybersecurity.com>
- Cc: cado-nfs@inria.fr
- Subject: Re: [cado-nfs] Inquiry about solving DLP on ARM processor and 386-bit DLP on intel processor
- Date: Tue, 12 Jul 2022 22:44:59 -0700
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Emmanuel.Thome@inria.fr; dmarc=fail (p=none dis=none) d=inria.fr
Hi,
I'm sorry, I meant to answer your emails earlier, but I was busy with
other things.
You're touching on two topics:
1 - linear algebra for DLP is _presently_ only for x86_64. This is what
is blocking you on arm, and presently you can't go further. Yes, your
analysis of the CMakeLists.txt file is correct.
For your information, if you were still struggling with linear algebra
for DLP on x86_64, it sould be good to know that the code requires that
the modulus width be explicitly covered in the compile time settings. The
setting that you can act upon is to be put in local.sh, for example like
this:
BWC_GFP_ARITHMETIC_BACKENDS=p_4
(you can also have a list such as BWC_GFP_ARITHMETIC_BACKENDS="p_1;p_4;pz")
However, this width should be compiled in by default (see there:
https://gitlab.inria.fr/cado-nfs/cado-nfs/-/blob/master/linalg/bwc/CMakeLists.txt#L27
), so really this only matters for primes larger than 15 machine words.
2 - as Paul said, you need parameter files for your dlog size. There are
two distinct parameter files that you need.
- The params.pNNN file. (used for all stages of the computation)
- The pNNN.hint file. (used only for the individual log phase at the very
end)
Starting points for both can be found in parameters/dlp/ for smaller
sizes. However, obtaining new parameters files is not an easy matter,
unfortunately. It requires a good understanding of the mechanics that
underpin the NFS algorithm in general. This is true of the params.pNNN
file, and perhaps even more obvious in the pNNN.hint. No, it is
unfortunate, be we do not have scripts to automate this.
Note that the considerations of point 1 will change soon, since I'm
currently working on changing the arithmetic layer of linear algebra.
(hard-coding will still be useful, but will become optional).
Best regards,
E.
On Tue, Jul 05, 2022 at 11:55:17AM +0900, 酒見由美 wrote:
> Dear developers of cado-nfs
> Sorry, here is the attachment.
> Best regards,
> Yumi
> 2022年7月5日(火) 11:51 酒見由美 <yumi.sakemi@gmo-cybersecurity.com>:
> > Hi, developers of cado-nfs.
> > Currently, I have two troubles in solving DLPs using cado-nfs.
> > It would be helpful if you could share information and references on the
> > causes and countermeasures for the below two troubles.
> > I would be grateful if you could advise me.
> > 1. Error "Exception: Program failed" occurred when I executed the solving
> > program for DLP on the ARM processor.
> > The build condition and execution environment when I have trouble are as
> > follows.
> > - Build by the default of cado-nfs
> > - EC2 with t4g.medium instance-type on AWS
> > - OS: Ubuntu 20.04 LTS.
> > In detail, I attached an error log "error_log_solving_DLP_on_arm.txt" to
> > this email.
> > 2. Error occurred when I tried to solve a large-size DLP.
> > In the case of 256-bit DLP, the solving program was successfully finished
> > however I try to solve 386-bit DLP, and the error occurs shown in
> > "error_log_for_large_size_DLP.txt".
> > follows.
> > - EC2 with t2.medium instance-type on AWS
> > Best regards,
> > Yumi
> > PS. I appreciate your OSS activities in the cryptanalysis program.
> > Yumi Sakemi, Ph. D.
> > GMO Cyber Security by IERAE, Inc.
> $ ./cado-nfs.py -dlp -ell
> 37858785688058251908976098251106649423874744726099768156267414181577309352921
> target=18305800997847417881820587816498923964203399308198405726066665615639898228686
> 75717571376116503817952196502213298847749489452199536312534828363154618705843
> &> arm_256bit_log.txt
> [32;1mInfo[0m:root: Using default parameter file
> ./parameters/dlp/params.p75
> [32;1mInfo[0m:root: No database exists yet
> [32;1mInfo[0m:root: Created temporary directory /tmp/cado.udicuapr
> [32;1mInfo[0m:Database: Opened connection to database
> /tmp/cado.udicuapr/p75.db
> [32;1mInfo[0m:root: Set tasks.linalg.bwc.threads=2 based on detected
> physical cores
> [32;1mInfo[0m:root: Set tasks.threads=2 based on detected logical cpus
> [32;1mInfo[0m:root: tasks.threads = 2 [via tasks.threads]
> [32;1mInfo[0m:root: tasks.polyselect.threads = 2 [via
> tasks.polyselect.threads]
> [32;1mInfo[0m:root: tasks.sieve.las.threads = 2 [via
> tasks.sieve.las.threads]
> [32;1mInfo[0m:root: tasks.linalg.bwc.threads = 2 [via
> tasks.linalg.bwc.threads]
> [32;1mInfo[0m:root: tasks.sqrt.threads = 2 [via tasks.threads]
> [32;1mInfo[0m:root: slaves.scriptpath is
> /home/ubuntu/cado-nfs/build/ip-172-31-22-60
> [32;1mInfo[0m:root: Using default hint file ./parameters/dlp/p75.hint
> [32;1mInfo[0m:root: Command line parameters: ./cado-nfs.py -dlp -ell
> [32;1mInfo[0m:root: If this computation gets interrupted, it can be
> resumed with ./cado-nfs.py /tmp/cado.udicuapr/p75.parameters_snapshot.0
> [32;1mInfo[0m:Server Launcher: Adding ip-172-31-22-60 to whitelist to
> allow clients on localhost to connect
> [32;1mInfo[0m:HTTP server: Using non-threaded HTTPS server
> [32;1mInfo[0m:HTTP server: Using whitelist: localhost,ip-172-31-22-60
> [32;1mInfo[0m:Lattice Sieving: param rels_wanted is 150000
> [32;1mInfo[0m:Complete Factorization / Discrete logarithm: Computing
> Discrete Logs in
> GF(75717571376116503817952196502213298847749489452199536312534828363154618705843)
> [32;1mInfo[0m:HTTP server: serving at https://ip-172-31-22-60:44681
> (0.0.0.0)
> [32;1mInfo[0m:HTTP server: For debugging purposes, the URL above can be
> accessed if the server.only_registered=False parameter is added
> [32;1mInfo[0m:HTTP server: You can start additional cado-nfs-client.py
> scripts with parameters: --server=https://ip-172-31-22-60:44681
> --certsha1=376913856580a8ed648ce2fa0515d72f82d90460
> [32;1mInfo[0m:HTTP server: If you want to start additional clients,
> remember to add their hosts to server.whitelist
> [32;1mInfo[0m:Client Launcher: Starting client id localhost on host
> localhost
> [32;1mInfo[0m:Client Launcher: Running clients: localhost (Host
> localhost, PID 143363)
> [32;1mInfo[0m:Polynomial Selection (size optimized): Starting
> [32;1mInfo[0m:Polynomial Selection (size optimized): 0 polynomials in
> queue from previous run
> [32;1mInfo[0m:Polynomial Selection (size optimized): Adding workunit
> p75_polyselect1_0-1000 to database
> p75_polyselect1_1000-2000 to database
> p75_polyselect1_2000-3000 to database
> p75_polyselect1_3000-4000 to database
> p75_polyselect1_4000-5000 to database
> [32;1mInfo[0m:HTTP server: 127.0.0.1 Sending workunit
> p75_polyselect1_0-1000 to client localhost
> p75_polyselect1_1000-2000 to client localhost
> [32;1mInfo[0m:Polynomial Selection (size optimized): Parsed 48
> polynomials, added 33 to priority queue (has 20)
> [32;1mInfo[0m:Polynomial Selection (size optimized): Worst polynomial in
> queue now has exp_E 23.420000
> [32;1mInfo[0m:Polynomial Selection (size optimized): Marking workunit
> p75_polyselect1_0-1000 as ok (20.0% => ETA Unknown)
> p75_polyselect1_2000-3000 to client localhost
> p75_polyselect1_3000-4000 to client localhost
> [32;1mInfo[0m:Polynomial Selection (size optimized): Parsed 46
> polynomials, added 6 to priority queue (has 20)
> queue now has exp_E 23.320000
> p75_polyselect1_1000-2000 as ok (40.0% => ETA Wed Jun 29 06:42:31 2022)
> [32;1mInfo[0m:Polynomial Selection (size optimized): Parsed 52
> polynomials, added 5 to priority queue (has 20)
> queue now has exp_E 23.220000
> p75_polyselect1_2000-3000 as ok (60.0% => ETA Wed Jun 29 06:42:24 2022)
> p75_polyselect1_4000-5000 to client localhost
> [32;1mInfo[0m:Polynomial Selection (size optimized): Parsed 49
> polynomials, added 2 to priority queue (has 20)
> queue now has exp_E 23.210000
> p75_polyselect1_3000-4000 as ok (80.0% => ETA Wed Jun 29 06:42:23 2022)
> [32;1mInfo[0m:Polynomial Selection (size optimized): Parsed 66
> polynomials, added 3 to priority queue (has 20)
> queue now has exp_E 23.120000
> p75_polyselect1_4000-5000 as ok (100.0% => ETA Wed Jun 29 06:42:22 2022)
> [32;1mInfo[0m:Polynomial Selection (size optimized): Finished
> [32;1mInfo[0m:Complete Factorization / Discrete logarithm: Polynomial
> [32;1mInfo[0m:Polynomial Selection (size optimized): Aggregate statistics:
> [32;1mInfo[0m:Polynomial Selection (size optimized): potential
> collisions: 620.92
> [32;1mInfo[0m:Polynomial Selection (size optimized): raw lognorm
> (nr/min/av/max/std): 427/24.450/28.556/31.210/0.879
> [32;1mInfo[0m:Polynomial Selection (size optimized): optimized lognorm
> (nr/min/av/max/std): 261/24.710/27.519/30.330/1.072
> [32;1mInfo[0m:Polynomial Selection (size optimized): Total time: 4.75
> [32;1mInfo[0m:Polynomial Selection (root optimized): Starting
> [32;1mInfo[0m:Polynomial Selection (root optimized): No polynomial was
> previously found
> [32;1mInfo[0m:Polynomial Selection (root optimized): Adding workunit
> p75_polyselect2_0-1 to database
> p75_polyselect2_6-7 to database
> p75_polyselect2_12-13 to database
> p75_polyselect2_18-19 to database
> [32;1mInfo[0m:HTTP server: 127.0.0.1 Sending workunit p75_polyselect2_0-1
> to client localhost
> [32;1mInfo[0m:HTTP server: 127.0.0.1 Sending workunit p75_polyselect2_6-7
> to client localhost
> [32;1mInfo[0m:Polynomial Selection (root optimized): New best polynomial
> from file /tmp/cado.udicuapr/p75.upload/p75.polyselect2.rlt5v8qi.opt_0:
> Murphy E = 6.599e-07
> [32;1mInfo[0m:Polynomial Selection (root optimized): Best polynomial from
> file /tmp/cado.udicuapr/p75.upload/p75.polyselect2.rlt5v8qi.opt_0 with
> E=5.811e-07 is no better than current best with E=6.599e-07
> E=6.138e-07 is no better than current best with E=6.599e-07
> Murphy E = 7.632e-07
> E=6.027e-07 is no better than current best with E=7.632e-07
> E=5.765e-07 is no better than current best with E=7.632e-07
> [32;1mInfo[0m:Polynomial Selection (root optimized): Marking workunit
> p75_polyselect2_0-1 as ok (10.0% => ETA Unknown)
> p75_polyselect2_12-13 to client localhost
> file /tmp/cado.udicuapr/p75.upload/p75.polyselect2.blzvx0zo.opt_6 with
> E=7.159e-07 is no better than current best with E=7.632e-07
> E=5.741e-07 is no better than current best with E=7.632e-07
> E=5.439e-07 is no better than current best with E=7.632e-07
> E=6.172e-07 is no better than current best with E=7.632e-07
> E=5.975e-07 is no better than current best with E=7.632e-07
> E=6.241e-07 is no better than current best with E=7.632e-07
> p75_polyselect2_6-7 as ok (40.0% => ETA Wed Jun 29 06:43:05 2022)
> p75_polyselect2_18-19 to client localhost
> from file /tmp/cado.udicuapr/p75.upload/p75.polyselect2.c32lnxvq.opt_12:
> Murphy E = 9.475e-07
> file /tmp/cado.udicuapr/p75.upload/p75.polyselect2.c32lnxvq.opt_12 with
> E=6.141e-07 is no better than current best with E=9.475e-07
> E=6.056e-07 is no better than current best with E=9.475e-07
> E=6.724e-07 is no better than current best with E=9.475e-07
> E=7.384e-07 is no better than current best with E=9.475e-07
> E=6.482e-07 is no better than current best with E=9.475e-07
> p75_polyselect2_12-13 as ok (70.0% => ETA Wed Jun 29 06:42:45 2022)
> file /tmp/cado.udicuapr/p75.upload/p75.polyselect2.v4dxgynd.opt_18 with
> E=5.988e-07 is no better than current best with E=9.475e-07
> E=7.005e-07 is no better than current best with E=9.475e-07
> p75_polyselect2_18-19 as ok (100.0% => ETA Wed Jun 29 06:42:39 2022)
> [32;1mInfo[0m:Polynomial Selection (root optimized): Kept 2 polynomials
> with MurphyE from 9.475e-07 to 7.632e-07
> [32;1mInfo[0m:Polynomial Selection (root optimized): Polynomial
> /tmp/cado.udicuapr/p75.poly.0 had MurphyE 9.475e-07, refined to 9.354e-07
> /tmp/cado.udicuapr/p75.poly.1 had MurphyE 7.632e-07, refined to 7.627e-07
> [32;1mInfo[0m:Polynomial Selection (root optimized): Best polynomial is
> [32;1mInfo[0m:Polynomial Selection (root optimized): Finished, best
> polynomial has Murphy_E = 9.475e-07
> [32;1mInfo[0m:Polynomial Selection (root optimized): Best polynomial is:
> n:
> skew: 6377.187
> c0: 2423935560124074183
> c1: 3510734203542523
> c2: -196452236552
> c3: -44125094
> c4: 4200
> Y0: -2719280983555840900
> Y1: 250114718177417
> # MurphyE (Bf=5.243e+05,Bg=5.243e+05,area=4.823e+10) = 9.475e-07
> # f(x) =
> 4200*x^4-44125094*x^3-196452236552*x^2+3510734203542523*x+2423935560124074183
> # g(x) = 250114718177417*x-2719280983555840900
> [32;1mInfo[0m:Polynomial Selection (root optimized): Best overall
> polynomial was 2-th in list after size optimization
> [32;1mInfo[0m:Polynomial Selection (root optimized): Aggregate statistics:
> [32;1mInfo[0m:Polynomial Selection (root optimized): Total time: 10.85
> [32;1mInfo[0m:Polynomial Selection (root optimized): Rootsieve time: 10.64
> [32;1mInfo[0m:Number Theory for DLP: Starting
> [32;1mInfo[0m:Complete Factorization / Discrete logarithm: Number Theory
> for DLP
> [32;1mInfo[0m:Number Theory for DLP: Total cpu/real time for
> numbertheory_tool: 0.05/0.0641508
> [32;1mInfo[0m:Generate Factor Base: Starting
> [32;1mInfo[0m:Generate Factor Base: Finished
> [32;1mInfo[0m:Complete Factorization / Discrete logarithm: Generate
> Factor Base
> [32;1mInfo[0m:Generate Factor Base: Total cpu/real time for makefb:
> 0.07/0.0356665
> [32;1mInfo[0m:Generate Free Relations: Starting
> [32;1mInfo[0m:Generate Free Relations: Found 1769 free relations
> [32;1mInfo[0m:Generate Free Relations: Finished
> [32;1mInfo[0m:Complete Factorization / Discrete logarithm: Generate Free
> Relations
> [32;1mInfo[0m:Generate Free Relations: Total cpu/real time for freerel:
> 0.63/0.368738
> [32;1mInfo[0m:Lattice Sieving: Starting
> [32;1mInfo[0m:Lattice Sieving: We want 150000 relation(s)
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_23000-25000 to
> database
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_25000-30000 to
> database
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_30000-35000 to
> database
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_35000-40000 to
> database
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_40000-45000 to
> database
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_45000-50000 to
> database
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_50000-55000 to
> database
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_55000-60000 to
> database
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_60000-65000 to
> database
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_65000-70000 to
> database
> p75_sieving_23000-25000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_70000-75000 to
> database
> p75_sieving_25000-30000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_75000-80000 to
> database
> [32;1mInfo[0m:Lattice Sieving: Found 2325 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.23000-25000.v0p2vbni.gz', total is now
> 2325/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_23000-25000
> as ok (1.6% => ETA Unknown)
> p75_sieving_30000-35000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_80000-85000 to
> database
> [32;1mInfo[0m:Lattice Sieving: Found 5406 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.25000-30000.ly3t_7p8.gz', total is now
> 7731/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_25000-30000
> as ok (5.2% => ETA Wed Jun 29 06:54:45 2022)
> p75_sieving_35000-40000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_85000-90000 to
> database
> [32;1mInfo[0m:Lattice Sieving: Found 5795 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.30000-35000.t1ufobgb.gz', total is now
> 13526/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_30000-35000
> as ok (9.0% => ETA Wed Jun 29 06:51:11 2022)
> p75_sieving_40000-45000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_90000-95000 to
> database
> [32;1mInfo[0m:Lattice Sieving: Found 4893 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.35000-40000.7z6na4jc.gz', total is now
> 18419/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_35000-40000
> as ok (12.3% => ETA Wed Jun 29 06:50:17 2022)
> p75_sieving_45000-50000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_95000-100000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 4654 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.40000-45000.1yjsytc7.gz', total is now
> 23073/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_40000-45000
> as ok (15.4% => ETA Wed Jun 29 06:50:01 2022)
> p75_sieving_50000-55000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_100000-105000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 4645 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.45000-50000.yqd348j3.gz', total is now
> 27718/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_45000-50000
> as ok (18.5% => ETA Wed Jun 29 06:49:45 2022)
> p75_sieving_55000-60000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_105000-110000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 4121 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.50000-55000.745ig_ih.gz', total is now
> 31839/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_50000-55000
> as ok (21.2% => ETA Wed Jun 29 06:50:02 2022)
> p75_sieving_60000-65000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_110000-115000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 4569 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.55000-60000._zh9s361.gz', total is now
> 36408/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_55000-60000
> as ok (24.3% => ETA Wed Jun 29 06:49:56 2022)
> p75_sieving_65000-70000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_115000-120000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 4098 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.60000-65000.ogew5f51.gz', total is now
> 40506/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_60000-65000
> as ok (27.0% => ETA Wed Jun 29 06:49:47 2022)
> p75_sieving_70000-75000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_120000-125000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3827 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.65000-70000.ixmkzczu.gz', total is now
> 44333/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_65000-70000
> as ok (29.6% => ETA Wed Jun 29 06:49:44 2022)
> p75_sieving_75000-80000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_125000-130000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3647 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.70000-75000.vt79y08l.gz', total is now
> 47980/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_70000-75000
> as ok (32.0% => ETA Wed Jun 29 06:49:42 2022)
> p75_sieving_80000-85000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_130000-135000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3501 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.75000-80000.6mr3g9ti.gz', total is now
> 51481/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_75000-80000
> as ok (34.3% => ETA Wed Jun 29 06:49:42 2022)
> p75_sieving_85000-90000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_135000-140000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3690 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.80000-85000.6kuwhr_7.gz', total is now
> 55171/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_80000-85000
> as ok (36.8% => ETA Wed Jun 29 06:49:43 2022)
> p75_sieving_90000-95000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_140000-145000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3339 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.85000-90000.wff6kii4.gz', total is now
> 58510/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_85000-90000
> as ok (39.0% => ETA Wed Jun 29 06:49:44 2022)
> p75_sieving_95000-100000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_145000-150000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3769 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.90000-95000.sjbyih03.gz', total is now
> 62279/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_90000-95000
> as ok (41.5% => ETA Wed Jun 29 06:49:45 2022)
> p75_sieving_100000-105000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_150000-155000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3532 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.95000-100000.bhno3ww1.gz', total is now
> 65811/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_95000-100000
> as ok (43.9% => ETA Wed Jun 29 06:49:45 2022)
> p75_sieving_105000-110000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_155000-160000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3640 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.100000-105000.7efx8vcu.gz', total is now
> 69451/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_100000-105000
> as ok (46.3% => ETA Wed Jun 29 06:49:46 2022)
> p75_sieving_110000-115000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_160000-165000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3170 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.105000-110000.p5oqsbuc.gz', total is now
> 72621/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_105000-110000
> as ok (48.4% => ETA Wed Jun 29 06:49:45 2022)
> p75_sieving_115000-120000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_165000-170000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3257 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.110000-115000.3sr_dtms.gz', total is now
> 75878/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_110000-115000
> as ok (50.6% => ETA Wed Jun 29 06:49:47 2022)
> p75_sieving_120000-125000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_170000-175000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3221 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.115000-120000.7kpygr6s.gz', total is now
> 79099/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_115000-120000
> as ok (52.7% => ETA Wed Jun 29 06:49:48 2022)
> p75_sieving_125000-130000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_175000-180000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2800 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.120000-125000._pvavzlw.gz', total is now
> 81899/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_120000-125000
> as ok (54.6% => ETA Wed Jun 29 06:49:49 2022)
> p75_sieving_130000-135000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_180000-185000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2638 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.125000-130000.lq_xq4_3.gz', total is now
> 84537/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_125000-130000
> as ok (56.4% => ETA Wed Jun 29 06:49:51 2022)
> p75_sieving_135000-140000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_185000-190000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3185 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.130000-135000.v4jdvyjk.gz', total is now
> 87722/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_130000-135000
> as ok (58.5% => ETA Wed Jun 29 06:49:53 2022)
> p75_sieving_140000-145000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_190000-195000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3078 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.135000-140000.nef6sv3q.gz', total is now
> 90800/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_135000-140000
> as ok (60.5% => ETA Wed Jun 29 06:49:54 2022)
> p75_sieving_145000-150000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_195000-200000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3022 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.140000-145000.qbdreyfd.gz', total is now
> 93822/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_140000-145000
> as ok (62.5% => ETA Wed Jun 29 06:49:56 2022)
> p75_sieving_150000-155000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_200000-205000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2703 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.145000-150000.p2p41l2f.gz', total is now
> 96525/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_145000-150000
> as ok (64.3% => ETA Wed Jun 29 06:49:57 2022)
> p75_sieving_155000-160000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_205000-210000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 3166 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.150000-155000.ddor2op5.gz', total is now
> 99691/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_150000-155000
> as ok (66.5% => ETA Wed Jun 29 06:50:00 2022)
> p75_sieving_160000-165000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_210000-215000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2570 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.155000-160000.xqdw3b4_.gz', total is now
> 102261/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_155000-160000
> as ok (68.2% => ETA Wed Jun 29 06:50:02 2022)
> p75_sieving_165000-170000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_215000-220000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2719 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.160000-165000.16if7eqh.gz', total is now
> 104980/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_160000-165000
> as ok (70.0% => ETA Wed Jun 29 06:50:03 2022)
> p75_sieving_170000-175000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_220000-225000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2705 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.165000-170000.ebucnx73.gz', total is now
> 107685/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_165000-170000
> as ok (71.8% => ETA Wed Jun 29 06:50:04 2022)
> p75_sieving_175000-180000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_225000-230000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2927 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.170000-175000.gnm_9a6f.gz', total is now
> 110612/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_170000-175000
> as ok (73.7% => ETA Wed Jun 29 06:50:06 2022)
> p75_sieving_180000-185000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_230000-235000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2762 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.175000-180000.jh5r0d0y.gz', total is now
> 113374/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_175000-180000
> as ok (75.6% => ETA Wed Jun 29 06:50:08 2022)
> p75_sieving_185000-190000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_235000-240000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2450 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.180000-185000.31dqkaej.gz', total is now
> 115824/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_180000-185000
> as ok (77.2% => ETA Wed Jun 29 06:50:10 2022)
> p75_sieving_190000-195000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_240000-245000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2669 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.185000-190000.y40cnlwt.gz', total is now
> 118493/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_185000-190000
> as ok (79.0% => ETA Wed Jun 29 06:50:10 2022)
> p75_sieving_195000-200000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_245000-250000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2659 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.190000-195000.4thspo60.gz', total is now
> 121152/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_190000-195000
> as ok (80.8% => ETA Wed Jun 29 06:50:13 2022)
> p75_sieving_200000-205000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_250000-255000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2668 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.195000-200000.2jge8n9u.gz', total is now
> 123820/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_195000-200000
> as ok (82.5% => ETA Wed Jun 29 06:50:14 2022)
> p75_sieving_205000-210000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_255000-260000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2586 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.200000-205000.j_htsunz.gz', total is now
> 126406/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_200000-205000
> as ok (84.3% => ETA Wed Jun 29 06:50:16 2022)
> p75_sieving_210000-215000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_260000-265000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2730 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.205000-210000.71vru5s8.gz', total is now
> 129136/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_205000-210000
> as ok (86.1% => ETA Wed Jun 29 06:50:18 2022)
> p75_sieving_215000-220000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_265000-270000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2455 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.210000-215000.5wahqzbi.gz', total is now
> 131591/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_210000-215000
> as ok (87.7% => ETA Wed Jun 29 06:50:20 2022)
> p75_sieving_220000-225000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_270000-275000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2535 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.215000-220000.203nkedy.gz', total is now
> 134126/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_215000-220000
> as ok (89.4% => ETA Wed Jun 29 06:50:21 2022)
> p75_sieving_225000-230000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_275000-280000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2275 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.220000-225000.7r45zxk6.gz', total is now
> 136401/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_220000-225000
> as ok (90.9% => ETA Wed Jun 29 06:50:23 2022)
> p75_sieving_230000-235000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_280000-285000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2584 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.225000-230000.m3rz2tl1.gz', total is now
> 138985/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_225000-230000
> as ok (92.7% => ETA Wed Jun 29 06:50:23 2022)
> p75_sieving_235000-240000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_285000-290000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2391 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.230000-235000.7drcntq2.gz', total is now
> 141376/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_230000-235000
> as ok (94.3% => ETA Wed Jun 29 06:50:26 2022)
> p75_sieving_240000-245000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_290000-295000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2376 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.235000-240000.c60_e9ge.gz', total is now
> 143752/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_235000-240000
> as ok (95.8% => ETA Wed Jun 29 06:50:28 2022)
> p75_sieving_245000-250000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_295000-300000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2419 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.240000-245000.vsusbu6d.gz', total is now
> 146171/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_240000-245000
> as ok (97.4% => ETA Wed Jun 29 06:50:29 2022)
> p75_sieving_250000-255000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_300000-305000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2393 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.245000-250000.vn3vejpp.gz', total is now
> 148564/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_245000-250000
> as ok (99.0% => ETA Wed Jun 29 06:50:31 2022)
> p75_sieving_255000-260000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_305000-310000
> to database
> [32;1mInfo[0m:Lattice Sieving: Found 2295 relations in
> '/tmp/cado.udicuapr/p75.upload/p75.250000-255000.jfq2r4wy.gz', total is now
> 150859/150000
> [32;1mInfo[0m:Lattice Sieving: Marking workunit p75_sieving_250000-255000
> as ok (100.6% => ETA Wed Jun 29 06:50:33 2022)
> p75_sieving_260000-265000 to client localhost
> [32;1mInfo[0m:Lattice Sieving: Adding workunit p75_sieving_310000-315000
> to database
> [32;1mInfo[0m:Lattice Sieving: Reached target of 150000 relations, now
> have 150859
> [32;1mInfo[0m:Complete Factorization / Discrete logarithm: Lattice Sieving
> [32;1mInfo[0m:Lattice Sieving: Aggregate statistics:
> [32;1mInfo[0m:Lattice Sieving: Total number of relations: 150859
> [32;1mInfo[0m:Lattice Sieving: Average J: 962.547 for 19936 special-q,
> max bucket fill -bkmult 1.0,1s:1.399220
> [32;1mInfo[0m:Lattice Sieving: Total time: 464.53s
> [32;1mInfo[0m:Filtering - Duplicate Removal, splitting pass: Starting
> [32;1mInfo[0m:Filtering - Duplicate Removal, splitting pass: Splitting 47
> new files
> [32;1mInfo[0m:Filtering - Duplicate Removal, splitting pass: Relations
> per slice: 0: 74671, 1: 76188
> [32;1mInfo[0m:Complete Factorization / Discrete logarithm: Filtering -
> [32;1mInfo[0m:Filtering - Duplicate Removal, splitting pass: Total
> cpu/real time for dup1: 0.66/0.615932
> [32;1mInfo[0m:Filtering - Duplicate Removal, splitting pass: Aggregate
> statistics:
> [32;1mInfo[0m:Filtering - Duplicate Removal, splitting pass: CPU time for
> dup1: 0.5s
> [32;1mInfo[0m:Filtering - Duplicate Removal, removal pass: Starting
> [32;1mInfo[0m:Filtering - Duplicate Removal, removal pass: 45765 unique
> relations remain on slice 0
> [32;1mInfo[0m:Filtering - Duplicate Removal, removal pass: 46531 unique
> relations remain on slice 1
> [32;1mInfo[0m:Filtering - Duplicate Removal, removal pass: Of 150859
> newly added relations 92296 were unique (ratio 0.611803)
> [32;1mInfo[0m:Filtering - Duplicate Removal, removal pass: 92296 unique
> relations remain in total
> [32;1mInfo[0m:Filtering - Duplicate Removal, removal pass: Total cpu/real
> time for dup2: 0.92/0.757699
> [32;1mInfo[0m:Filtering - Duplicate Removal, removal pass: Aggregate
> statistics:
> [32;1mInfo[0m:Filtering - Duplicate Removal, removal pass: CPU time for
> dup2: 0.6s
> Galois
> [32;1mInfo[0m:Filtering - Singleton removal: Starting
> [32;1mInfo[0m:Filtering - Singleton removal: Reading 92296 unique and
> 1769 free relations, total 94065
> [32;1mInfo[0m:Filtering - Singleton removal: After purge, 44751 relations
> with 44749 primes remain with weight 990885 and excess 2
> [32;1mInfo[0m:Filtering - Singleton removal: Have enough relations
> [32;1mInfo[0m:HTTP server: Got notification to stop serving Workunits
> [32;1mInfo[0m:Lattice Sieving: Cancelling remaining workunits
> [32;1mInfo[0m:Client Launcher: Stopped client localhost (Host localhost,
> PID 143363)
> Singleton removal
> [32;1mInfo[0m:Filtering - Singleton removal: Total cpu/real time for
> purge: 0.94/0.994134
> [32;1mInfo[0m:Filtering - Merging: Starting
> [32;1mInfo[0m:Filtering - Merging: Merged matrix has 15784 rows and total
> weight 1587959 (100.6 entries per row on average)
> Merging
> [32;1mInfo[0m:Filtering - Merging: Total cpu/real time for merge-dl:
> 1.45/0.896545
> [32;1mInfo[0m:Filtering - Merging: Total cpu/real time for replay-dl:
> 0.45/0.417745
> [32;1mInfo[0m:Schirokauer Maps: Starting
> [32;1mInfo[0m:Complete Factorization / Discrete logarithm: Schirokauer
> Maps
> [32;1mInfo[0m:Schirokauer Maps: Total cpu/real time for sm: 255.42/145.667
> [32;1mInfo[0m:Linear Algebra: Starting
> [32;1mInfo[0m:Linear Algebra: Using 2 as default value for n to account
> for Schirokauer maps
> [32;1mInfo[0m:Linear Algebra: Using 2*n=4 as default value for m
> [33;1mWarning[0m:Command: Process with PID 145092 finished with return
> code 25
> [31;1mError[0m:Linear Algebra: Program run on server failed with exit
> code 25
> [31;1mError[0m:Linear Algebra: Command line was:
> /home/ubuntu/cado-nfs/build/ip-172-31-22-60/linalg/bwc/bwc.pl :complete
> 'thr=2' 'm=4' 'n=2' 'nullspace=right'
> 'matrix=/tmp/cado.udicuapr/p75.sparse.bin' 'rhs=/tmp/cado.udicuapr/p75.sm'
> 'prime=37858785688058251908976098251106649423874744726099768156267414181577309352921'
> 'wdir=/tmp/cado.udicuapr/p75.bwc'
> 'cpubinding=/home/ubuntu/cado-nfs/parameters/misc/cpubinding.conf' >
> /tmp/cado.udicuapr/p75.bwc.stdout.1 2> /tmp/cado.udicuapr/p75.bwc.stderr.1
> [31;1mError[0m:Linear Algebra: Stderr output (last 10 lines only) follow
> (stored in file /tmp/cado.udicuapr/p75.bwc.stderr.1):
> [31;1mError[0m:Linear Algebra: # (88102f56a)
> /home/ubuntu/cado-nfs/build/ip-172-31-22-60/linalg/bwc/prep
> cpubinding=/home/ubuntu/cado-nfs/parameters/misc/cpubinding.conf thr=1x2
> n=2 nullspace=right m=4 wdir=/tmp/cado.udicuapr/p75.bwc
> [31;1mError[0m:Linear Algebra: # Compiled with gcc 9.4.0
> [31;1mError[0m:Linear Algebra: # Compilation flags (C) -std=c99 -W
> -Wall -O2
> [31;1mError[0m:Linear Algebra: # Compilation flags (C++)
> -export-dynamic -std=c++17 -Wno-c++11-compat -W -Wall -O2
> -Wno-literal-suffix
> [31;1mError[0m:Linear Algebra: Unsupported combination: group size =
> 1, p =
> 37858785688058251908976098251106649423874744726099768156267414181577309352921,
> 4 limbs
> 1, p =
> 4 limbs
> /home/ubuntu/cado-nfs/build/ip-172-31-22-60/linalg/bwc/prep: exited with
> status 1
> [31;1mError[0m:Linear Algebra: aborted on subprogram error at
> /home/ubuntu/cado-nfs/build/ip-172-31-22-60/linalg/bwc/bwc.pl line 528, <F>
> line 1.
> [31;1mError[0m:Linear Algebra: ...propagated at
> /home/ubuntu/cado-nfs/build/ip-172-31-22-60/linalg/bwc/bwc.pl line 1581,
> <F> line 1.
> 0.07/0.0356665
> 1.45/0.896545
> 0.45/0.417745
> statistics:
> dup2: 0.6s
> statistics:
> dup1: 0.5s
> collisions: 620.92
> 0.63/0.368738
> [32;1mInfo[0m:HTTP server: Shutting down HTTP server
> Traceback (most recent call last):
> File "./cado-nfs.py", line 202, in <module>
> factors = factorjob.run()
> File "/home/ubuntu/cado-nfs/./scripts/cadofactor/cadotask.py", line 6296,
> in run
> last_status = task.run()
> File "/home/ubuntu/cado-nfs/./scripts/cadofactor/cadotask.py", line 4624,
> in run
> raise Exception("Program failed")
> 53926009017978931736984806740113026324519998535824380426446749962534715549311211341622943100075880341970608372363249
> target=102288176212936607159280477504841059965918817023586481232254591814905168142261279360250750495442674650825329787346070
> 10785201803595786347396961348022605264903999707164876085289349992506943109862242268324588620015176068394121674472649
> &> intel_386bit_log.txt
> File "./cado-nfs.py", line 144, in <module>
> parameters, db = toplevel_params.get_cooked_parameters()
> File "/home/ubuntu/cado-nfs/./scripts/cadofactor/toplevel.py", line 1175,
> in get_cooked_parameters
> self.set_N_paramfile_workdir()
> File "/home/ubuntu/cado-nfs/./scripts/cadofactor/toplevel.py", line 647,
> in set_N_paramfile_workdir
> self.args.parameters = self.find_default_parameter_file()
> File "/home/ubuntu/cado-nfs/./scripts/cadofactor/toplevel.py", line 186,
> in find_default_parameter_file
> raise RuntimeError("no parameter file found"
> RuntimeError: no parameter file found for p116 (tried p116, p115)
> Feel free to submit one!
Pour une évaluation indépendante, transparente et rigoureuse !
Je suis à la CE de l'Inria pour y apporter ma contribution.
- [cado-nfs] Inquiry about solving DLP on ARM processor and 386-bit DLP on intel processor, 酒見由美, 07/05/2022
- Re: [cado-nfs] Inquiry about solving DLP on ARM processor and 386-bit DLP on intel processor, 酒見由美, 07/05/2022
- Re: [cado-nfs] Inquiry about solving DLP on ARM processor and 386-bit DLP on intel processor, Paul Zimmermann, 07/05/2022
- Re: [cado-nfs] Inquiry about solving DLP on ARM processor and 386-bit DLP on intel processor, Emmanuel Thomé, 07/13/2022
