- To: Ed Hall <ed_ka2fwj@yahoo.com>
- Cc: Emmanuel.Thome@inria.fr, cado-nfs@inria.fr
- Subject: Re: [cado-nfs] Excessive lingen Time for Processing
- Date: Mon, 18 Jul 2022 10:57:53 +0200
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@tomate
Ed,
please can you try your longer run (with msieve) after setting
OMP_DYNAMIC=true as follows?
$ export OMP_DYNAMIC=true
Best regards,
Paul
> Date: Sat, 16 Jul 2022 13:17:06 +0000 (UTC)
> From: Ed Hall <ed_ka2fwj@yahoo.com>
> Cc: "cado-nfs@inria.fr" <cado-nfs@inria.fr>
> [1:text/plain Show]
> [2:text/html Hide Save:noname (4kB)]
> Hi Emmanuel,
> I'm still slightly confused with the suggestion.
> According to grep:
> $ grep -r "OMP_DYNAMIC" *
> ci/03-check.sh:export OMP_DYNAMIC=true STATS_PARSING_ERRORS_ARE_FATAL=1
> gf2x/ci/03-check.sh:export OMP_DYNAMIC=true STATS_PARSING_ERRORS_ARE_FATAL=1
> tests/CMakeLists.txt:# cautious. Setting OMP_DYNAMIC=true seems to alleviate
> this problem
> It looks as though OMP_DYNAMIC is already set to true. But, the CADO-NFS
> package is too complicated for my amateur level of programming knowledge.
> Should I be inserting "OMP_DYNAMIC=true" into a command during the build or
> running of CADO-NFS?
> Thanks for all the help
> Sincerely,
> Edwin Hall
- [cado-nfs] Excessive lingen Time for Processing, Ed Hall, 07/15/2022
- Re: [cado-nfs] Excessive lingen Time for Processing, Emmanuel Thomé, 07/16/2022
- Re: [cado-nfs] Excessive lingen Time for Processing, Ed Hall, 07/16/2022
- Re: [cado-nfs] Excessive lingen Time for Processing, Paul Zimmermann, 07/18/2022
- Re: [cado-nfs] Excessive lingen Time for Processing, Ed Hall, 07/18/2022
- Re: [cado-nfs] Excessive lingen Time for Processing, Emmanuel Thomé, 07/19/2022
- Re: [cado-nfs] Excessive lingen Time for Processing, eric . jeancolas, 07/19/2022
