- To: Paul Leyland <paul.leyland@gmail.com>
- Cc: cado-nfs@inria.fr
- Subject: Re: [cado-nfs] Parameter documentatin.
- Date: Tue, 04 Jul 2023 15:25:01 +0200
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@coriandre
Hi Paul,
> Date: Thu, 29 Jun 2023 15:08:21 +0100
> From: Paul Leyland <paul.leyland@gmail.com>
> A quick question: are all settable parameters documented
> parameters/factor/params.c90 or is there some additional documentation I
> have yet to find?
all parameters should be there. If you find a missing one, please report.
> I'm running a factorization which is at, or somewhat beyond, the present
> limits of my system and would like to understand what else I can
> optimize. As just one example, it is quite important to set
> tasks.sqrt.threads to a small value to keep memory usage within
> reasonable limits.
Good luck!
Paul
- Re: [cado-nfs] Parameter documentatin., Paul Zimmermann, 07/04/2023
- Re: [cado-nfs] Parameter documentatin., eric . jeancolas, 07/05/2023
- Re: [cado-nfs] Parameter documentatin., Paul Zimmermann, 07/06/2023
