- To: Markus Tervooren <mail@markustervooren.de>
- Cc: cado-nfs@inria.fr
- Subject: Re: [cado-nfs] Issue with "purge" on C210 GNFS
- Date: Wed, 20 Nov 2024 13:59:30 +0100
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail smtp.mailfrom=Paul.Zimmermann@inria.fr; spf=None smtp.helo=postmaster@coriandre
Hi Markus,
> After 43 days of matrix computation, the factorization successfully
> completed with an <84>*<126> split. It's truly remarkable how well the
> tools perform!
> 494539244937099339417399923739685270133264934572503968644362756106164055715558162053<84>
> 470213758850664488575979215230457822052887477247960356471935464748052891586623372725737258341194401849441525126055605188999307<126>
good to hear, thank you for the feedback!
Paul
- Re: [cado-nfs] Issue with "purge" on C210 GNFS, Markus Tervooren, 11/20/2024
- Re: [cado-nfs] Issue with "purge" on C210 GNFS, Paul Zimmermann, 11/20/2024
- <Possible follow-up(s)>
