Re: [cado-nfs] Can using multiple factor bases be used for computing discrete logarithm faster ?
- To: Laël Cellier <lael.cellier@laposte.net>
- Cc: cado-nfs@inria.fr
- Subject: Re: [cado-nfs] Can using multiple factor bases be used for computing discrete logarithm faster ?
- Date: Mon, 25 Nov 2024 08:02:22 +0100
- Authentication-results: mail2-relais-roc.national.inria.fr; dkim=none (message not signed) header.i=none
Hi Laël,
I didn't know this paper. I had a quick look. Here are my thoughts:
- this is an L(1/2) algorithm, while NFS is an L(1/3) algorithm.
Asymptotically, this can not win against NFS. The crossover depends on
implementations, but usually it is around 100 digits inputs.
- the improve the individual logarithm step, which is the less costly
among all the steps.
- actually, I am not sure this is a real improvement compared to the
naive approach.
- the individual logarithm step is different in NFS, so that the
technique can not be transposed to this algorithm.
To conclude: I might be wrong (of course), but I don't think this has any
chance to be interesting for large scale computations.
Regards,
Pierrick
On Sun, Nov 24, 2024 at 04:59:32PM +0100, Laël Cellier wrote:
> Bonjour,
> I was reading this paper : https://arxiv.org/pdf/2409.08784. Although it
> contains rants and the timings are questionable unless they only have their
> phones, the underying idea is to pick up several factor bases instead of 1
> in order to shrink the number of individual discrete logarithms for a given
> target.
> Now, I’m only a beginner, but is this an idea that can be useful for more
> advanced algorithms ? They give full step by step of their textbook
> algorithm.
> Cordialement,
- [cado-nfs] Can using multiple factor bases be used for computing discrete logarithm faster ?, Laël Cellier, 11/24/2024
- Re: [cado-nfs] Can using multiple factor bases be used for computing discrete logarithm faster ?, Pierrick Gaudry, 11/25/2024
- Re: [cado-nfs] Can using multiple factor bases be used for computing discrete logarithm faster ?, Laël Cellier, 11/25/2024
