cgal-discuss - Re: [cgal-discuss] operator '<' overloaded
  • To:
  • Subject: Re: [cgal-discuss] operator '<' overloaded
  • Date: Mon, 04 Dec 2006 15:21:33 +0100
My first try would be to use a std::map<Facet_handle,..>
If that does not work out of the box you must write a functor
comparing two handles, by comparing the adress of the
dereferenced handle.
struct HandleLess {
bool oprator()(const Facet_handle& fh1, const Facet_handle& fh2) const
return &(*fh1) < &(*fh2);
e};
and put this as third argument in the map
andreas
wrote:
Hello,
I use a std::map<,> in my code,
and received a message as follows.
< Error message
c:/NAGAI/MinGW/bin/../lib/gcc/mingw32/3.4.2/../../../../include/c++/3.4.2/bits/stl_function.h:227:
error: no match for 'operator<' in '__x < __y'
C:/NAGAI/CGAL/CGAL-3.2.1/include/CGAL/Gmpz.h:151: note: candidates are: bool
CGAL::operator<(const CGAL::Gmpz&, int)
C:/NAGAI/CGAL/CGAL-3.2.1/include/CGAL/Gmpz.h:139: note: bool
CGAL::operator<(const CGAL::Gmpz&, const CGAL::Gmpz&)
C:/NAGAI/CGAL/CGAL-3.2.1/include/CGAL/MP_Float.h:269: note: bool
CGAL::operator<(const CGAL::MP_Float&, const CGAL::MP_Float&)
I think this error is related to overloading the operator '<' in CGAL.
All of the code is long, so I'll show a part of it.
I skipped many parts of code which I consider they mean nothing to this
problem.
< A part of codes
struct ControlPointsOfFacet{
Point p[ 10 ];
class Surface{
public:
Polyhedron surfaceMesh;
std::map< FacetIterator, ControlPointsOfFacet > controlPoint;
...( in another member function of class Surface )
Surface surface;
FacetIterator fit = surface.surfaceMesh.facets_begin();
ControlPointsOfFacet cp;
cp.p[0]=Point(...);
cp.p[9]=Point(...);
controlPoint.insert( std::make_pair( fit, cp ) );
How can I fix this problem?
Regards,
Yukie NAGAI
