- To:
- Subject: Re: [cgal-discuss] Visual Studio 2005 (v.8)
- Date: Fri, 08 Dec 2006 11:56:38 +0100
wrote:
Can anyone give me any advice on how to set-up Visual Studio 2005 to use CGAL.
I'm sure if I can hack at it for a while I can get it to happen, but
hopefully someone out-there has already done this and can make it easy for me.
Ideally, can someone post a nice zipped up minimal project that compiles VS8?
Yours hopefully,
Keith Ealanta
For VC++ you should install CGAL with the selfextracting archive and not
use the tar.gz
The cgal.lib is precompiled with VC7. In order to recompile go in
the directoy CGAL-3.2./src/CGAL, open the vcprof file and click
on rebuild. The same for Core, and CGALQt, if you need them (and
have Qt 3 for Windows).
In the examples and demo directory, you find the .vcproj files.
That is clicking on it and clicking on build solution, should do it.
There is one thing that needs attention for VC8. Visual 8 now comes with the
Dinkumware STL implementation. You currently have to disable two checking
features
of this STL In the IDE go to Project-> ... properties->C/C++->Preprocessor and
add _SECURE_SCL=0 _HAS_ITERATOR_DEBUGGING=0 to "Preprocessor Definitions".
The first define avoids warnings, the second one assertions at runtime.
Whereas the first one concerns a non portable "improvement" of the STL
which makes it less "S" (which after all stands for Standard), we work
on the second one.
best regards,
andreas
- Visual Studio 2005 (v.8), keith, 12/08/2006
- RE: [cgal-discuss] Visual Studio 2005 (v.8), lihw, 12/08/2006
- Re: [cgal-discuss] Visual Studio 2005 (v.8), Andreas Fabri, 12/08/2006
- Re: [cgal-discuss] Visual Studio 2005 (v.8), Keith Ealanta, 12/08/2006
- Re: [cgal-discuss] Visual Studio 2005 (v.8), Hongbo Fu, 12/08/2006
- Re: [cgal-discuss] Visual Studio 2005 (v.8), Keith Ealanta, 12/09/2006
- HOWTO setup Visual Studio 2005 (v.8) to use CGAL, Keith Ealanta, 12/09/2006
- [EMERGENCY] BUG??? DelaunayTriangulation, lihw, 12/09/2006
