cgal-discuss - Re: [cgal-discuss] Visual Studio 2005 (v.8)
  • To:
  • Subject: Re: [cgal-discuss] Visual Studio 2005 (v.8)
  • Date: Fri, 8 Dec 2006 21:50:47 +0800
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=beta; d=gmail.com; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references; b=rTYYu5JwULdA+uEYAp+AceTkFY63gpg4B1wehG2Qx5/P3EXU1yT1UOPXHuslQH9KEH+omslUw6Fw3OqTiI3lEO1n/03d7udjWK3dQXSmnw7BK2KVNs0uKzX8Sy2z5Az91g9gTs2f6TF2IyVgaoKhemqVM4RIoZB4XfNdh5Mkn0Y=
Wrong setting of runtime library (under projection properties | C/C++
| Code Generation) often leads to such errors.
You can check if multi-threaded debug dll (/MDd) is used for the debug mode.
On 12/8/06, Keith Ealanta
wrote:
Andreas Fabri wrote:
wrote:
>> Can anyone give me any advice on how to set-up Visual Studio 2005 to
>> use CGAL.
>> I'm sure if I can hack at it for a while I can get it to happen, but
>> hopefully someone out-there has already done this and can make it easy
>> for me.
>> Ideally, can someone post a nice zipped up minimal project that
>> compiles VS8?
>> Yours hopefully,
>> Keith Ealanta
> For VC++ you should install CGAL with the selfextracting archive and not
> use the tar.gz
> The cgal.lib is precompiled with VC7. In order to recompile go in
> the directoy CGAL-3.2./src/CGAL, open the vcprof file and click
> on rebuild. The same for Core, and CGALQt, if you need them (and
> have Qt 3 for Windows).
> In the examples and demo directory, you find the .vcproj files.
> That is clicking on it and clicking on build solution, should do it.
> There is one thing that needs attention for VC8. Visual 8 now comes
> with the
> Dinkumware STL implementation. You currently have to disable two
> checking features
> of this STL In the IDE go to Project-> ...
> properties->C/C++->Preprocessor and
> add _SECURE_SCL=0 _HAS_ITERATOR_DEBUGGING=0 to "Preprocessor Definitions".
> The first define avoids warnings, the second one assertions at runtime.
> Whereas the first one concerns a non portable "improvement" of the STL
> which makes it less "S" (which after all stands for Standard), we work
> on the second one.
> best regards,
> andreas
Thanks heaps for this.
Once I'm all done I might try to throw together a quick howto you could
put up somewhere.
One issue I'm having. I built the libraries (release and debug versions)
When I compile a debug version of one of the examples I get the linker
warning... (in this case I was building the Nef_2 Simple_Intersection
example)
simple_intersection.obj : error LNK2019: unresolved external symbol
__imp___CrtDbgReportW referenced in function "public: class
std::list<class CGAL::Extended_segment<class CGAL::Gmpz>,class
std::allocator<class CGAL::Extended_segment<class CGAL::Gmpz> >
>::_Const_iterator<1> & __thiscall std::list<class
CGAL::Extended_segment<class CGAL::Gmpz>,class std::allocator<class
>::_Const_iterator<1>::operator--(void)"
(??F?$_Const_iterator@$00@?$list@V?$Extended_segment@VGmpz@CGAL@@@CGAL@@V?$allocator@V?$Extended_segment@VGmpz@CGAL@@@CGAL@@@std@@@std@@QAEAAV012@XZ)
I don't get this when I build in release, but of course that rather
limits my debugging. Am I just doing something dumb or is there some
other detail I've missed?
Again, many thanks,
Keith Ealanta
Homepage: http://ihome.ust.hk/~fuhb
Department of Computer Science and Engineering
Hong Kong University of Science and Technology
