cgal-discuss - Re: [cgal-discuss] Problem compiling with CGAL-3.2.1 under Linux
  • To:
  • Subject: Re: [cgal-discuss] Problem compiling with CGAL-3.2.1 under Linux
  • Date: Tue, 12 Dec 2006 07:20:22 +0100
Jeronymo Peixoto Athayde Pereira wrote:
Hi,
I have been using Exact_predicates_exact_constructions_kernel with CGAL-3.0.1
without problems. Recently, I have switched to CGAL-3.2.1 and my code does
not compile any more.
The part of the code that does not compile is as follows
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel<double> Kernel;
Remove the <double> as it IS NOT a template, just as the compiler says.
And then let's have a look at the next error mesages.
andreas
The compiler issues the following error message
buildcrack_cgal.h:115:* error:
CGAL::Exact_predicates_exact_constructions_kernel is not a template*
I took a look at the CGAL/Exact_predicates_exact_constructions_kernel.h in
which we have
typedef Filtered_kernel<Simple_cartesian<Lazy_exact_nt<Quotient<MP_Float> > >
Exact_predicates_exact_constructions_kernel;
So, I tried:
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Filtered_kernel.h>
#include <CGAL/Lazy_exact_nt.h>
typedef
CGAL::Filtered_kernel<CGAL::Simple_cartesian<CGAL::Lazy_exact_nt<CGAL::Quotient<realType>
> > > Kernel
It works but it does not compile other parts of the code.
I also tried to compile with Simple_Cartesian and it compiles without
problems but I need to used Exact_predicates_exact_constructions_kernel in my
code.
By the way, I am using *g++ (GCC) 4.1.2 20061115 (prerelease) (SUSE Linux).
*Does anyone know why I'm having this problem?
Thanks a lot!
JP
