- To:
- Subject: Re: [cgal-discuss] fatal error C1067
- Date: Tue, 12 Dec 2006 09:08:58 +0800
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=beta; d=gmail.com; h=received:message-id:date:from:to:subject:in-reply-to:mime-version:content-type:references; b=mNFU3MdV1mXzOlN3p8VUuOxUkvcebo6Rmx2bjxaTi09O9No/l3gTJ9tkFTxGxfTXgCxtn/ncXUyRPs9FGnqwg6pDOpLyKLgv+inivZdJoesv5jqYjUMuWEd8Iul+TcNN1Qan0ekkRBwoBQ2vMSaw/7FKd1nA6M16DrHXWiQ3yjg=
Thank you very much.
On 12/10/06, Keith Ealanta <> wrote:
Firstly, (just in case you don't know this one) if you select the error
message and hit F1 it should give you more information.
In this case the error info is...
"Error Message
compiler limit : 64K limit on size of a type record has been exceeded
This error could occur if a symbol has a decorated name exceeding 247
characters. To resolve, shorten the symbol name.
When the compiler generates debug information, it emits type records to
define types encountered in source code. For example, type records
include simple structures and argument lists of functions. Some of these
type records can be large lists.
There is a 64K limit on the size of any type record. If that 64K limit
is exceeded then this error will occur.
C1067 can also occur if there are many symbols with long names or if a
class, struct, or union has too many members."
Given the lengths some of the template names run to, long names seems a
likely cause.
I don't actually know the solution to this one, but I seem to recall it
being mentioned in one of the faq, the documentation or the mailing list.
I'd search through them for info on long symbol names.
Good luck,
Keith Ealanta
Linker Lee wrote:
> Hi,
> When I try to compile \CGAL-3.2\demo\Arrangement_2, I encounter the
> following message:
> ------ ?????: ??: arrangement_2, ??: Debug Win32 ------
> MyWindow_files.C
> d:\Program Files\Microsoft Visual Studio .NET
> 2003\Vc7\include\list(255) : fatal error C1067: ????? : ???
> ???????"file://d:\Program
> Files\Cgal-3.2\demo\Arrangement_2\Debug\BuildLog.htm"?
> arrangement_2 - 1 ??,0 ??
> ??: 0 ???, 1 ???, 0 ???
> What can I do?
> Thank you very much in advance.
> Regards,
> Linker Lee
------Linker Lee
- fatal error C1067, Linker Lee, 12/09/2006
- Re: [cgal-discuss] fatal error C1067, Keith Ealanta, 12/10/2006
- Re: [cgal-discuss] fatal error C1067, Linker Lee, 12/12/2006
