- To:
- Subject: Re: [cgal-discuss] 3D Polyhedrons intersections
- Date: Tue, 12 Dec 2006 21:44:31 +0100
Hello,
When you have facets with more than three vertices they must be
coplanar, which might not be given if their coordinates are doubles.
The solution is to either make them coplanar, or to triangulate
the faces.
best regards,
andreas
wrote:
Hello,
I am very new to CGAL, and I am wondering if it is possible to do
solid/solid intersections.
It is funny to see that infact, I have the same question as Cedric
Le Maitre (he sent a mail today)...
More precisely, I have two solids described by two closed Polyhedra
(using 3 and 4 nodes faces).
I would like to get the Polyhedra that represents the difference between
the two solids.
I tried using the Nef_polyhedron_3 classes :
1- construct two Polyhedron
2- construct the Nef_polyhedron from the 2 polyhedron
3- intersect the 2 Nef_polyhedron
4- convert the result back to a Polyhedron
When I construct the nef associated with one of the Polyhedrons, I
get the following error :
CGAL error: assertion violation!
Expr: pe_prev->facet()->plane().
has_on(pe_prev->opposite()->vertex()->point())
File: ./cgal_build/CGAL-3.2.1/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h
Line: 151
I had a look in this file, but the error is not so obvious, at least for
a 'CGAL-beginner' like me.
Could anyone guide me, and tell me if such operation is available in
CGAL, and if yes, how to achieve it ? Any help would be greatly
appreciated.
Best Regards,
Frederic.
- 3D Polyhedrons intersections, frederic . feyel, 12/12/2006
- Re: [cgal-discuss] 3D Polyhedrons intersections, Andreas Fabri, 12/12/2006
- Re: [cgal-discuss] 3D Polyhedrons intersections, Frédéric FEYEL, 12/12/2006
- Message not available
- Re: [cgal-discuss] 3D Polyhedrons intersections, FEYEL Frederic., 12/13/2006
- Re: [cgal-discuss] 3D Polyhedrons intersections, Peter Hachenberger, 12/13/2006
- Re: [cgal-discuss] 3D Polyhedrons intersections, Frédéric FEYEL, 12/13/2006
- Re: [cgal-discuss] 3D Polyhedrons intersections, FEYEL Frederic., 12/14/2006
- Re: [cgal-discuss] 3D Polyhedrons intersections, Andreas Fabri, 12/14/2006
