cgal-discuss - Re: [cgal-discuss] 3D Polyhedrons intersections
  • To:
  • Subject: Re: [cgal-discuss] 3D Polyhedrons intersections
  • Date: Tue, 12 Dec 2006 23:06:07 +0100 (CET)
  • Importance: Normal
Thank you for your advice.
I changed my closed surface so that it contains only 3-nodes
facets, so that all facets are obviously planar.
However, the same problem is still there:
CGAL error: assertion violation!
Expr: pe_prev->facet()->plane().
has_on(pe_prev->opposite()->vertex()->point())
File: ./cgal_build/CGAL-3.2.1/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h
Does anyone has some extra clues ?
Thank you very much for your help,
Best Regards,
Frederic.
Andreas Fabri a écrit :
> Hello,
> When you have facets with more than three vertices they must be
> coplanar, which might not be given if their coordinates are doubles.
> The solution is to either make them coplanar, or to triangulate
> the faces.
> best regards,
> andreas
> wrote:
>> Hello,
>> I am very new to CGAL, and I am wondering if it is possible to do
>> solid/solid intersections.
>> It is funny to see that infact, I have the same question as Cedric
>> Le Maitre (he sent a mail today)...
>> More precisely, I have two solids described by two closed Polyhedra
>> (using 3 and 4 nodes faces).
>> I would like to get the Polyhedra that represents the difference between
>> the two solids.
>> I tried using the Nef_polyhedron_3 classes :
>> 1- construct two Polyhedron
>> 2- construct the Nef_polyhedron from the 2 polyhedron
>> 3- intersect the 2 Nef_polyhedron
>> 4- convert the result back to a Polyhedron
>> When I construct the nef associated with one of the Polyhedrons, I
>> get the following error :
>> Line: 151
>> I had a look in this file, but the error is not so obvious, at least for
>> a 'CGAL-beginner' like me.
>> Could anyone guide me, and tell me if such operation is available in
>> CGAL, and if yes, how to achieve it ? Any help would be greatly
>> appreciated.
>> Best Regards,
>> Frederic.
