- To:
- Subject: Re: stl map using facet_handle as key
- Date: Wed, 13 Dec 2006 11:19:57 +0100
additional information:
I have displayed the value received from
controlPoint[ f0 ].p[ 0 ]
in my program as I wrote,
and the result was like this:
controlPoint[ f0 ].p[ 0] = 4.17201e-309 1.89119e-307 1.6135e-307
But, there is no such a datum in my input
(controlPoint[facet_handle].p[0] stores an input value itself,
so I searched this value in the input data).
The map itself was made correctly.
So I think this value is CGAL-native data, somewhat like infinite point in
Delaunay triangulation...I don't know if there is such a value in
Polyhedron_3 and why this value was returned to f0, a facet iterator related
to real datum.
How I get correct value from this map with facet_handle key ?
Thanks,
NAGAI, Yukie
- stl map using facet_handle as key, ueberweise, 12/13/2006
- <Possible follow-up(s)>
- Re: stl map using facet_handle as key, ueberweise, 12/13/2006
