- To:
- Subject: Re: [cgal-discuss] Re: CGAL: DelaunayTriangulation compile error with gcc 4.1
- Date: Wed, 13 Dec 2006 04:18:19 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type:Content-Transfer-Encoding:Message-ID; b=YDzqXs/Jcm0HrdVJe8RWeqeEnn2GcfeZi4wojfGyYQ87Dmm5gJYyZqZXJaYlpFWsvMzmRShxLngNtz58H37YiKzSLtfa34KHL24Ag3kbP1SHIt3nqxJjxE5KxINrNOT5c+EGo9YxQ29PTsZHlVyR1/4iwx/5yRtuV+zQ5RuiVOY=;
hi
5 month ago i joined cgalgroup ,
and from that time all mails between people sended for me!!!!!!!!!!!!!!!!!!!!!!!1
how can i prevent getting your mails?
thank
parastoo saadat
sorry for my reaction time.
I transfer you message to the cgal user list
Stefan Schiffer a écrit :
>Dear Mariette Yvinec,
> I am writing you because of a problem I have with the CGAL Delaunay
> Triangulation and your name appears as author in the respective header.
> Currently, I am a PhD student at the Knowledge-based Systems Group at
> RWTH Aachen University. We are using CGAL within our robot software and
> we employ Delaunay Triangulation for qualitative world modelling.
> Recently, I tried to compile the respective module with gcc 4.1 and I
> encountered a problem that I am not able to solve. I am now turning to
> you since I am not sure whether this may be a shortcoming in CGAL. If
> it is a (known?) CGAL-problem, you can perhaps help me out, if it is
> not you may nonetheless be able to help me.
> To make sure the problem is not inherent in my code (which I debugged
> for several days now) I started from scratch with the example-code
> provided with CGAL and I could reproduce the particular error.
> Here's the code:
>-------8<--------------------------------------------------------------
>#include
>#include
>#include
>struct K : CGAL::Exact_predicates_inexact_constructions_kernel {};
>typedef CGAL::Delaunay_triangulation_2Triangulation;
>typedef Triangulation::Edge_iterator Edge_iterator;
>typedef Triangulation::Point Point;
>int main( )
> Triangulation T;
> T.insert( Point( 1.0, 0.1 ));
> T.insert( Point( 2.0, 0.1 ));
> T.insert( Point( 1.0, 0.3 ));
> T.insert( Point( 5.0, 0.2 ));
> int ns = 0;
> int nr = 0;
> Edge_iterator eit =T.edges_begin();
> for ( ; eit !=T.edges_end(); ++eit) {
> CGAL::Object o = T.dual(eit);
> K::Segment_2 s;
> K::Ray_2 r;
> if (CGAL::assign(s,o)) {++ns;}
> if (CGAL::assign(r,o)) {++nr;}
> std::cout << "The voronoi diagram as " << ns << "finite edges "
> << " and " << nr << " rays" << std::endl;
> return 0;
>------->8--------------------------------------------------------------
> When I try to compile this with gcc 4.0, everything is fine, but when
> using gcc 4.1 instead, I get the following errors (shortened for
> readability):
> CGAL/Delaunay_triangulation_2.h:389: error: no matching function for
> call to 'circumcenter...
> CGAL/Delaunay_triangulation_2.h:521: error: no matching function for call
> to 'side_of_oriented_circle...
> I also tried a compile-flag I found within the code (because I figured
> it would have something to do with making the two function circumcenter
> and side_of_oriented_circle visible from the base class
> (Triangulation_2.h):
> #define CGAL_CFG_USING_BASE_MEMBER_BUG_2
> This leeds to the following additional error message (again shortened
> for readability):
> CGAL/Delaunay_triangulation_2.h:228: error: there are no arguments to
> 'ccw' that depend on a template parameter, so a declaration of 'ccw'
> must be available
> CGAL/Delaunay_triangulation_2.h:247: error: there are no arguments to
> 'cw' that depend on a template parameter, so a declaration of 'cw' must
> be available
> Do you have any idea what this is about?
> Could this perhaps have something to do with
> http://www.parashift.com/c++-faq-lite/templates.html#faq-35.18
> I don't mean to bother you but I'd highly appreciate any comment!
> Don't hesitate to ask for further information if you need them.
> Thanks a lot and sorry for the inconvenience.
>Yours sincerely,
> Stefan Schiffer
Need a quick answer? Get one in minutes from people who know. Ask your question on Yahoo! Answers.
- Re: [cgal-discuss] Re: CGAL: DelaunayTriangulation compile error with gcc 4.1, parastoo saadat, 12/13/2006
- Re: [cgal-discuss] Re: CGAL: DelaunayTriangulation compile error with gcc 4.1, Mariette Yvinec, 12/13/2006
- Re: [cgal-discuss] Re: CGAL: DelaunayTriangulation compile error with gcc 4.1, Stefan Schiffer, 12/13/2006
