cgal-discuss - Influence of Delaunay triangulations on seeded random number generators
  • To:
  • Subject: Influence of Delaunay triangulations on seeded random number generators
  • Date: Fri, 22 Dec 2006 14:22:11 +0100
Hi,
I came across the following: when I create a instance of a
Random_points_in_sphere_3 generator with a fixed random seed, then the
points are the same every time, except when I instantiate a Delaunay
triangulation before the creation of the points. Here is some code (I have
attached the complete code):
int main( )
Triangulation dt;
for (int i = 0; i < 5; i++) {
std::cout << *pgen << std::endl;
pgen++;
return 0;
This program produces points with different coordinates each time it is
run. When I uncomment the line 'Triangulation dt;', then the output is
always the same.
I suspect that one is supposed to be able to build a Delaunay triangulation
of random, but reproducible, numbers. Therefore I assume this might be a
bug. Can anyone confirm that the expected behaviour is that the randomly
generated points are identical on each run? Can the problem be reproduced?
I have not bothered to investigate the problem beyond isolating it. I
presume, assuming that this is a bug, that the Delaunay triangulation
makes some use of random numbers at initialisation, but this probably
should not affect anything outside the Triangulation object itself.
Matthijs Sypkens Smit
#include <CGAL/Delaunay_triangulation_3.h>
#include <CGAL/point_generators_3.h>
#include <CGAL/Random.h>
#include <CGAL/Point_3.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Delaunay_triangulation_3<K>               Triangulation;
typedef CGAL::Point_3<K>                                    Point;
typedef CGAL::Creator_uniform_3<double,Point>                 Pt_creator;
typedef CGAL::Random_points_in_sphere_3<Point,Pt_creator>     Sphere_pgen;
CGAL::Random rnd( 2 );
Sphere_pgen pgen( 1.0, rnd );
int main( )
    Triangulation dt;
        pgen++;
    return 0;
