cgal-discuss - Re: [cgal-discuss] Influence of Delaunay triangulations on seeded random number generators
  • To:
  • Subject: Re: [cgal-discuss] Influence of Delaunay triangulations on seeded random number generators
  • Date: Fri, 22 Dec 2006 21:42:13 +0100
  • Organization: INRIA Sophia Antipolis, France
Matthijs Sypkens Smit wrote:
I came across the following: when I create a instance of a Random_points_in_sphere_3 generator with a fixed random seed, then the points are the same every time, except when I instantiate a Delaunay triangulation before the creation of the points. Here is some code (I have attached the complete code):
int main( )
Triangulation dt;
for (int i = 0; i < 5; i++) {
std::cout << *pgen << std::endl;
pgen++;
return 0;
This program produces points with different coordinates each time it is run. When I uncomment the line 'Triangulation dt;', then the output is always the same.
I suspect that one is supposed to be able to build a Delaunay triangulation of random, but reproducible, numbers. Therefore I assume this might be a bug. Can anyone confirm that the expected behaviour is that the randomly generated points are identical on each run? Can the problem be reproduced?
I have not bothered to investigate the problem beyond isolating it. I presume, assuming that this is a bug, that the Delaunay triangulation makes some use of random numbers at initialisation, but this probably should not affect anything outside the Triangulation object itself.
You guessed right that CGAL::Random is also used by
Delaunay_triangulation internally (for randomized algorithms purposes,
since the output is deterministic). CGAL::Random simply calls the
standard rand() function, which unfortunately uses a global state.
I guess the best long term fix would be to switch to the random number
generators defined in TR1 (part of the next C++ standard).
There is a second issue here, which is that the random number generator
inside Delaunay_triangulation is default constructed, which calls
time() to get a non-deterministic (well, non-constant) seed...
And there is no control over that.
Depending on what you need, the easiest thing to do is to pass a
CGAL::Random object to the constructor of
Delaunay_triangulation_3 (and down to its Triangulation_3 base class).
Note that if you use Triangulation_hierarchy_3, there is the same
problem there...
If you really need separate random states, then it's harder, since
rand() must be replaced by something that supports a state
(drand48_r() does it, but is probably not portable).
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project
CGAL, http://cgal.org/
