- To:
- Subject: RE:Re: [cgal-discuss] Problem in transformation of Nef_3 polyhedron
- Date: Fri, 16 Feb 2007 21:06:36 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:user-agent:mime-version:to:subject:references:in-reply-to:content-type:content-transfer-encoding:sender; b=LzBkdvfVysVOCk+TrJJox5FvW1aqV3f+QFsXKph/eHdfwTzCJSGSlNnOjEWaGiyitB3Q/lI2wETynn4n+/0BMAdOvFx+qrKa7GT5TBbYwTl+MARPtlH9xhVZXw8AGx8ct+O6DrJgNL2I0h+2SVz73SPxb3cLRqWP4FZBN/RIPA0=
Hi Peter.
I understand what you mean. Maybe general transformation make
some vertices, which are on the same plane before the transformation,
not on the same plane after the transformation.
If I have some of line equations and calculate the intersections of the
line
with a plane using CGAL, are those intersection points are on the same
plane without rounding problem ?
Wonwoo.
Peter Hachenberger wrote:
> Hi,
> transformin Nef polyhedra can be quite complicated. That's why I tried
> to only allow a subset of all possible transformations. We did not test
> the code for general transformations. There are two things you should
> change. First, you should do two separate transformations: one
> translation and one rotation. Second, if it still does not work, you
> should use a rational rotation matrix for the rotation. The rotation
> that you perform will probably deform the polyhedron because of rounding
> issues. The code is only tested with rotations that do not deform the
> polyhedron. You can look up how to do it in demo/Nef_3/nef_3.C. There we
> handle rotations around all three coordinate axis. Search for the key
> word "rotx".
> Peter
> On Sat, 2007-02-17 at 00:24 +0900, Wonwoo Lee wrote:
>> Hi.
>> I created a pyramid with Polyhedron_3 and converted to Nef_3
>> polyhedron.
>> Than, I appled a transformation, which consists of rotation and
>> translation by using Nef_polyhedron_3::Aff_transformation_3.
>> But after transformation. the Nef_3 polyhedron is not displayed in
>> OpenGL space.
>> If I apply only translation, it does not disappear. I think the
>> problem is in applying rotation.
>> What happens to my Nef_3 polyhedron ?
>> My code is something like below :
>> Nef_polyhedron_3 N ;
>> Nef_polyhedron_3::Aff_transformation_3 transf(1,0,0, 200,
>> 0,1/sqrt(2),-1/sqrt(2), 200,
>> 0,1/sqrt(2), 1/sqrt(2), 200) ;
>> N.transform(transf) ;
- Problem in transformation of Nef_3 polyhedron, Wonwoo Lee, 02/16/2007
- Message not available
- RE:Re: [cgal-discuss] Problem in transformation of Nef_3 polyhedron, wlee, 02/16/2007
- RE:Re: [cgal-discuss] Problem in transformation of Nef_3 polyhedron, Peter Hachenberger, 02/23/2007
