Re: [cgal-discuss] Problem with building CGAL 3.2.1 - possible GMP vs MPFR dependency issue
- To:
- Subject: Re: [cgal-discuss] Problem with building CGAL 3.2.1 - possible GMP vs MPFR dependency issue
- Date: Fri, 16 Feb 2007 19:05:44 +0100
Peter Schüller a écrit :
Dear CGAL Users and developers!
I have a problem building the latest CGAL-3.2.1. I have attached the
install.log
I assume the problem is that on my setup GMP is detected as "supported"
and MPFR as "not supported".
Because of GMP, include/CGAL/number_type_basic.h includes
include/CGAL/Gmpz.h
Gmpz.h unconditionally includes <mpfr.h> which leads to the errors.
Yes, if you select GMP support, you must have MPFR as well.
CGAL-3.1 built without problems.
Indeed, this is a change compared to 3.1.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project
CGAL, http://cgal.org/
- Problem with building CGAL 3.2.1 - possible GMP vs MPFR dependency issue, Peter Schüller, 02/16/2007
- Re: [cgal-discuss] Problem with building CGAL 3.2.1 - possible GMP vs MPFR dependency issue, Sylvain Pion, 02/16/2007
- Re: [cgal-discuss] Problem with building CGAL 3.2.1 - possible GMP vs MPFR dependency issue, Peter Schüller, 02/19/2007
