- To:
- Subject: Re: [cgal-discuss] Change the geometric information for a vertex?
- Date: Mon, 19 Feb 2007 14:34:13 +0100
wrote:
Hello,
What is the easiest way to change only the geometric information associated
with the vertices of a Delaunay triangulation? (e.g. in order to translate or
rotate the hole point cloud)
Thanks
Hi
As mentioned in the user manual of 3D Triangulation, using Triangulation_vertex_base_with_info_3 is the simplest way.
best
Monique Teillaud
- Change the geometric information for a vertex?, novacheva, 02/19/2007
- Re: [cgal-discuss] Change the geometric information for a vertex?, Monique . Teillaud, 02/19/2007
- Re: [cgal-discuss] Change the geometric information for a vertex?, Angelina Novacheva, 02/19/2007
- Re: [cgal-discuss] Change the geometric information for a vertex?, Andreas Fabri, 02/19/2007
