- To:
- Subject: Re: [cgal-discuss] Change the geometric information for a vertex?
- Date: Mon, 19 Feb 2007 16:47:13 +0100
Angelina Novacheva wrote:
Many thanks! The v.set_point ( Point p) was what I was
looking for.
What problems should I expect with arithmetics? The
rest of the TDS stays the same, right - all the
neighbourhood information etc.?
The data structure stays the same but the coordinates of the points will be rounded (because of sines and cosines that are not rational).
So, when you check whether the triangulation is still valid after the rotation, with the new coordinates, it can very well be that the orientation tests will return wrong values.
(also, the perturbation technique used internally to solve degenerate situations is not invariant through rotations, and this might cause other problems)
- Change the geometric information for a vertex?, novacheva, 02/19/2007
- Re: [cgal-discuss] Change the geometric information for a vertex?, Monique . Teillaud, 02/19/2007
- Re: [cgal-discuss] Change the geometric information for a vertex?, Angelina Novacheva, 02/19/2007
- Re: [cgal-discuss] Change the geometric information for a vertex?, Andreas Fabri, 02/19/2007
