- To:
- Subject: Re: [cgal-discuss] installation problem CGAL 3.2.1 +QT on linux
- Date: Fri, 16 Mar 2007 10:26:31 +0100
Hi,
> When installing CGAL 3.2.1 on T60 IBM running Ubuntu linux kernel
> 2.6.17-10, BOOST 1.33.1, QT 3.3.7 (I also tried other 3.x versions),
> using:
have you considered using the CGAL packages for Debian? They might also
work on Ubuntu. There are packages for Debian sarge (stable) and sid
(unstable) which you can get from the Debian repository or my homepage
http://www.joachim-reichel.de/debian/ . The packages for stable are also
available from www.cgal.org. Note that you also need to install the
libcore++{1c2,-dev} packages.
Regards,
Joachim
- installation problem CGAL 3.2.1 +QT on linux, alenas, 03/16/2007
- Re: [cgal-discuss] installation problem CGAL 3.2.1 +QT on linux, Laurent Rineau, 03/16/2007
- Re: [cgal-discuss] installation problem CGAL 3.2.1 +QT on linux, Joachim Reichel, 03/16/2007
