cgal-discuss - [cgal-discuss]Attach user data to the vertices of a Arrangement_2 during construction
  • To: "cgal-discuss" <>
  • Subject: [cgal-discuss]Attach user data to the vertices of a Arrangement_2 during construction
  • Date: Wed, 28 Mar 2007 12:20:38 +0800
  • Disposition-notification-to: "Wang Weiwei" <>
Hi all,
I'm using the Arrangement_2 module of CGAL.
I want to attach some user information to the vertices of the arrangement.
I've found some example code in the example folder of the CGAL lib (such as
ex_dcel_extension.C).
Unfortunately, in this example, the user data are attached to the vertices,
halfedges and faces after the arrangement was built. What I want to know is
how I can attach these user data to the vertices during the construction of
the arrangement. For those vertices newly created during the intersection of
the curves, a pre-specified default value will be ok.
Thanks in advance for any help.
Sorry for the previous message with the subject not correct.
Max
